Oil change issues
Old Jul 28, 2015 | 09:05 PM
SuperG96's Avatar
SuperG96
Default Oil change issues
Changed my oil just like every other time, switched over to amsoil 20-50. Put in 2.4qts, checked it cold it was too high on the stick, checked it after a ride and it was well over full. Whats the deal?
Old Jul 28, 2015 | 09:06 PM
SuperG96's Avatar
SuperG96
Btw, it was definately empty when i put the drain plug back in. No extra oil used in the filter
Old Jul 28, 2015 | 09:10 PM
charger426's Avatar
charger426
Kinda hard to help when we don't know what the year of bike you changed the oil in is. Have to ask did you get the bike hot before draining the oil?
Old Jul 28, 2015 | 09:19 PM
SuperG96's Avatar
SuperG96
08 super glide, changed when hot. Checked cold and hot
Old Jul 28, 2015 | 09:25 PM
charger426's Avatar
charger426
Another question that might seem dumb but gotta ask. After getting the bike hot you parked on level ground with the bike on the kickstand. Took the dipstick out wiped it off set it back in (not screwed on) and then checked it again right?
Old Jul 28, 2015 | 09:58 PM
slyedog's Avatar
slyedog
2 qts is safe to put half up when hot. Also reduces some potential blowby. You likely didn't drain an extra few oz you thought you did and added an extra couple and there is the difference. Hell 8oz (1/4 qt) can get you close to full hot after 2qts.
Old Jul 28, 2015 | 09:59 PM
SuperG96's Avatar
SuperG96
Manual says to screw cap on. I just took 8oz out of it and its right where it needs to be hot. Wierd? So it took 2.25 quarts instead of 2 1/2
SH_01FXDWG
Jun 13, 2015 05:13 PM
Mason34
Mar 8, 2015 09:36 PM
Wakko47
May 3, 2012 07:24 PM
Rickr01
Aug 8, 2011 01:46 PM
casadelray
May 13, 2010 06:18 PM
