Forward control complete...need help shifter arm
Old Aug 18, 2015 | 07:42 AM
mgilroy311's Avatar
mgilroy311
Stage III
Default Forward control complete...need help shifter arm
I installed the Kuryakyn forward controls and everything works fine, but I cant install the shifter arm. I can slide the shifter arm on the spine but Im having trouble bolting it down it seems like the actual bolt makes contact with spine not allowing it to engage the threaded side allowing it to tight down.
Old Aug 18, 2015 | 07:45 AM
sknyfats's Avatar
sknyfats
Pic might be helpful. I'm not sure whether you're talking about the inboard one or the outboard one that holds the shift peg.
Possible you're either using the wrong bolt (and used the right one somewhere else) or they gave you the wrong bolt.
Old Aug 18, 2015 | 07:49 AM
Uncle Larry's Avatar
Uncle Larry
It's hard to picture your dilemma, but it appears as though the lever isn't positioned properly ( deep enough? ) on the spline so the bolt can pass through the "slot" in the shifter shaft.
Old Aug 18, 2015 | 10:16 AM
emperor wurm's Avatar
emperor wurm
Are you taking the bolt completely off, then installing the shifter on the spline and then installing the bolt? If the bolt is not completely off the shifter, it will not slide on the shift shaft completely.
Old Aug 18, 2015 | 05:50 PM
JohnMn's Avatar
JohnMn
That's it,, you have to take the bolt all the way out,,
Old-Evo
EVO
25
Jun 4, 2024 03:31 PM
overthehill?
Oct 14, 2013 02:53 AM
daved3
Jun 7, 2010 11:10 AM
VINNIE JAMES
Jun 1, 2010 04:54 AM
speedkills
Mar 2, 2010 08:20 PM
