Dumped the bike for the first time.
Get that scoot back on the road and keep riding! Stay safe
Ps I would contact the city and let them know what happened
They'd just cut out a 6" deep, lane-wide 30 yard-long section of road and filled it back in with gravel. No signs, nothing. C***ts.
Pretty screwed up, but he was doing what he loved, fully accepted the risks, and it was a really nice day for a ride...
Anyway, re suing the city, you'll probably find that there are fairly strong legal protections for them re accidents caused by road conditions. It sucks, but its understandable. If they were liable for every pothole and bump in the road, their insurance premiums would be so high no roads would ever be built. If you see what I mean.
That said, this was in Australia, the law about that stuff might be different in the US.
My advice: hug your loved ones, and ride out to visit some others. Life is a gift, and you just got some more of it.
I've found after quite a bit of track riding and binning the bikes a time or two you should check out your forks, they'll tend to twist in the clamps and get put under tension when the bike goes down. At the track I'd put the bike on the race stands and start to loosen the pinch bolts, you'd hear the creaks and pops as the forks went back to their neutral position as the tension was released. I'd lift your bike and back off the pinch bolts and allow the fork tubes to resettle themselves if they need to.
Check out your bars and risers, you may find you've tweaked the bushings and the bars and risers are also twisted. If they are loosen up the riser bolts to reposition them, you may need to change your bushings if they were the OEM rubber bushings, those don't take much to distort and allow added bar/riser movement and vibrations...
