Will 11" Progressive Shocks cause pegs scraping when turning?
Old Sep 21, 2015 | 01:35 PM
2015 Harley Davidson Street Bob Guy's Avatar
Default Will 11" Progressive Shocks cause pegs scraping when turning?
I am at a stage trying to make my bike look lower but will this make life harder for me when taking corners?
I love the way it handles right now because i could take any corners without scraping my pegs.
Old Sep 21, 2015 | 01:39 PM
modular's Avatar
modular
If you are not currently dragging hard parts you are not riding hard enough.
That being said.....if you lower the rear end then yes, you will be more likely to drag said hard parts.
Old Sep 21, 2015 | 01:48 PM
OK thanks for the fast reply - I'm going to forget these shocks then i like my bike the way it is think i will go and do forward control instead
Old Sep 21, 2015 | 03:24 PM
PanHeadRich's Avatar
PanHeadRich
Forwards controls are another disadvantage when it comes to cornering. You'll have much better control over the bike with Mids. IMO softail cruisers are great for lowering & forward controls. But a Dyna is a lot more fun sitting higher with mid controls.
Old Sep 21, 2015 | 03:31 PM
DesertDyna's Avatar
DesertDyna
Naaaah! Cornering is just as fun with forward controls. I hang right in with the sport bikes on the twisties.
Old Sep 21, 2015 | 04:04 PM
Warp Factor's Avatar
Warp Factor
Depends on how hard you turn.
And the spring rate and preload of the 11" shocks.
Old Sep 21, 2015 | 05:38 PM
TinCupChalice's Avatar
TinCupChalice
Understanding and using proper riding techniques and correct bike setup will mitigate many of the ground clearance issues. I can run some pretty healthy well beyond legal speeds on my Wide Glide in the big sweepers around here by understanding and practicing proper cornering technique. Lots of track riding on sportbikes may have helped too...
Proper corner entry (outside the turn, inside the turn), throttle control and continuous roll-on throughout the turn, along with a more aggressive body position will all have a huge role in keeping the hard bits from touching down. Set your suspension to its stiffest settings, study cornering theory and practice it. The goal is a continuous throttle roll-on and a late turn-in. And you don't just sit there on the seat; get your body weight down and to the inside of the turn.
Old Sep 21, 2015 | 05:56 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
All good info!
You can have your cake and eat it too...lowered for the looks and still hit the corners hot and not drag, just adjust your riding style some...good to do anyway.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 21, 2015 | 07:28 PM
stev0n's Avatar
stev0n
have 3" extended forwards & progressive drop-ins front & 11" rear. only about 3/4 of an inch on either side of the tire isn't worn & my pipes scrape before anything else & even that is very rare.
Old Sep 21, 2015 | 08:57 PM
nevil's Avatar
nevil
I had 11.5" Progressives on the bike for a short time. It would easily scrape the pipes. I didn't really care about the pipes that much but got tired of dealing with less lean angle. And I don't ride nearly as aggressive as I used to.
Decided to change to 12.6" Ohlins, never hit the pipes after that and now I rarely scrape even the pegs.
