wire gauge
Old Nov 8, 2015 | 11:32 AM
Bill Golightly's Avatar
Bill Golightly
3rd Gear
Default wire gauge
I am trying to freshen up a 2003 FXDWG. I have plenty of manuals and diagrams, but I cannot find the original wire gauges for what is in the bike. Can someone post this info or tell me where to find it?
Thanks for your time.
Old Nov 8, 2015 | 01:52 PM
JohnMn's Avatar
JohnMn
It's a mix,, the harness's have all different gauges of wire,, maybe someone can help if your more specific about the location of wires you need.
Old Nov 8, 2015 | 01:58 PM
Bill Golightly
3rd Gear
Default good point
I would like to know all, probably will need to know sooner or later. But, the immediate need is the orange/white at the breaker panel, and the white in the high beam circuit.
Thanks for your reply.
Old Nov 8, 2015 | 03:04 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Wire size is determined by the load it's going to carry versus the distance it's going. I.E. batteries -6 or 8 ga., gauges 18 or 16 ga. You would have to take the harness out and take lots of notes as to what wire to what is what size, the wires should be marked.
Old Nov 9, 2015 | 09:39 AM
p51bombay's Avatar
p51bombay
That's not something that will be published, wire size will vary all over the place depending on load requirements for each circuit. If you need to know, buy a wire gauge and measure it.
Old Nov 9, 2015 | 11:50 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a link to some Wire Gauge Tables which will help you to determine the awg wire size needed.
Old Nov 10, 2015 | 08:49 AM
skinman13's Avatar
skinman13
That is a great chart!
Rule of thumb, you can run larger, but never run a wire that has a lower current rating than the fuse protecting the circuit. In other words, do not run a 20 gauge wire on a circuit that is protected by a 15 amp fuse. According to this chart, most of your general system wiring will be 16 - 18 gauge wires so you can probably safely use 18 gauge wire for all applications except starting and power generating circuits that will carry large current loads. These circuits will have larger gauge wire. Just use the fuse size and distance from the fuse to the device guide your choice for wire diameter. Going larger (lower gauge number) is OK, going smaller (higher gauge number) is not advised...the wire may burn up in the bundle before the fuse opens the circuit.
Wilkesfastjay
Audio Systems
Apr 20, 2019 07:29 AM
Valleyofthegun
Electrical/Lighting/Alarm
Mar 17, 2019 02:37 PM
zivkos
2018+ Softail Models
Mar 10, 2019 09:29 AM
TcHunter
Audio Systems
Jun 10, 2016 02:16 PM
AllenW
Apr 16, 2016 11:12 AM
