Clearview shield arrived...
Old Dec 3, 2015 | 08:13 AM
Mchad's Avatar
Mchad
Default First ride
Wow. That's it. Just wow.
Ok, some more detail. Absolutely 1000% improvement over the Memphis replacement shield I had in my HD QD brackets. I can feel the jetstream about 6" over the top of my head, which is perfect for when I use a FF vs. my half helm. When I lower the shield to reduce the gap above the headlight, it will still pass overhead. I felt around and had a small jet of air coming in that gap, over the tank, hitting my gut and rolling up my chest and into my face. Not bad, but there. Still much better overall then any shield I've had, and once I cut it to be able to lower it a bit (prob only an inch and a half due to the brackets), I think that will improve a lot. Still so good I didn't even pull the tube over my face, which I usually would when riding in 42 deg cold. Not bad!
The ride was a short one, only about 10 min and not more then about 55 (45mph back roads) so I need to get up to some speed, but I know it'll be great. Another benefit is the shield is wider, and I felt less wind on my hands - which is huge when i gets cold.
Here is the gap I mentioned. Once I cut out two notches for the sigs, I will be able to close it up a bit.
Old Dec 3, 2015 | 08:26 AM
Super08's Avatar
Super08
Good to hear you got the same kind of results as I did with mine even though it is a different style. I just love how effective mine is.
Old Dec 3, 2015 | 08:51 AM
fskitch's Avatar
fskitch
Have you considered replacing your headlight mounting block to one that will raise your headlight an an inch or two rather than trimming the shield? http://www.ebay.com/itm/Harley-headl...xWXOCu&vxp=mtr
Old Dec 3, 2015 | 10:11 AM
reedyjm's Avatar
reedyjm
Originally Posted by Super08
I am not sure if the HD ones would work or not. I could check it out. They only take a minute to remove anyway as it is only one hex screw that holds each side on. You can either remove the screw in the red circle that removes the clamp or the screw in the blue circle which will remove only the bracket and deflector, but leave the clamp in place on the fork tube. That way you don't need to adjust them each time.
Edit: I attached a picture to show how the clamps for the lowers look after removing them. It literally only takes a few seconds to remove or install them the way they are. If you don't like the look of the clamps left on the forks then remove the screw that releases the clamp instead. It takes longer that way as you will have to line them back up when re-installing.
Thanks for the great info! 1 more question; How tall are you and can you see over the 20" version? I am 5'11" and I want to see over the shield, so i'm not sure if I should go with the 20" or the 18.5".
Old Dec 3, 2015 | 12:17 PM
Mchad's Avatar
Mchad
I am 6'3" and I got the 23" version actually - I don't think it's on their site - but when I spoke to the guy there he suggested that height for me.
Right now, I can see over the top - Just. The road surface I can see without looking through the shield is about 30' in front of the front wheel.
Old Dec 3, 2015 | 12:20 PM
Mchad's Avatar
Mchad
I actually have a taller block, but I like the "low" bucket look, and I only use the screen in the fall/winter so I'd rather mod it and leave the headlight where it is. Good thought though. Thanks.
Old Dec 3, 2015 | 03:39 PM
Mchad's Avatar
Mchad
I just didn't have the ***** to make the cuts myself, so I stopped by a glass and mirror shop (coincidentally right next door to the body shop who did my tank) and asked them to make the cuts for me. $50 later I had exactly what I wanted. Now the shield is about an inch and a half lower and exactly where I wanted it. Here are the cuts.
Old Dec 3, 2015 | 07:03 PM
Super08's Avatar
Super08
Hey that looks really good!
As for my height, I am 6' and I look over mine.
Old Dec 3, 2015 | 08:23 PM
clap's Avatar
clap
Hey Mchad what size and model is the shield you bought. I have the HD QD shield on mine and it way to low and could be wider
Old Dec 3, 2015 | 09:30 PM
Mchad's Avatar
Mchad
The invoice has it listed as:
Dyna Wide Glide 06-Later fits HD Quick Release, Sportster /
Dyna fits Quick Release or Detachable Compact
23"H + 4"W Light Grey RECURVE
2632.177 847-7 CDG23G
