The FXRT / FXRP "Style" Dyna Fairing Thread
Anyway, this is the brand spanking new V2H or Villain2Hero FXRT / FXRP fairing. I apologize for the pictures not being the best since most of them are mid-install, but I plan on posting some more along with a full write-up/review after I get it all squared away.
To start, though, I went with this kit because it was the most affordable option to get a pre-painted Vivid / Gloss Black fairing and the wrap-around style clamp cleared my GPR Stabilizer mount.
I did take it for about an hour-long test ride, and I love it. I had to experiment a lot with my FXDXT style fairing to avoid buffeting. Even then, at high speeds, if I wasn't wearing my Icon Airflite compared to a Simpson Ghost Bandit, I couldn't avoid it.
However, this thing is awesome. I threw on a Klock Werks recurve windshield right out of the gate, so I don't know how much that makes a difference over a stock style, but it's like you're in a little bubble when riding.
There's definitely air moving around you; you know you're on a motorcycle, but it's just a lot smoother. Also, I'm 5' 8", and I went with the 9" windshield, so your mileage may vary.
Assuming you have stock Harley-Davidson front turn signals like mine, they're internally threaded 5/16"-24.
All I did was get a 1-1/2" long 5/16"-24 button head cap screw, drop it in from above, and then lock it down with a nyloc nut with washers on each side.
Then, the factory jam nut went on, followed by the turn signal itself.
When you're putting everything on, leave the nyloc nut a little loose, so you can still rotate the cap screw.
Then thread the jam nut on, and then you can rotate the entire screw assembly to tighten the turn signal down.
This will prevent you from having to spin the turn signal on, wrapping the wire harness all around itself.
Tighten the nyloc nut against the fairing, adjust the direction of your turn signal, and then lock it down with the jam nut.
Depending on how your lower mounts are, you could probably skip the double nut process and just tighten the turn signal housing down directly.
I didn't want to put the stress of the fairing mount on the turn signal housing, and I wanted to keep the ability to adjust the pointing direction of my turn signals.
anyone have one of these or seen one up close?
