Need Help! Wide Glide leaking Oil
Old May 9, 2007 | 10:56 PM
jdizzie's Avatar
jdizzie
Default Need Help! Wide Glide leaking Oil
So....
Right where the tranny connects to the motor on the top is wet with oil.
The bottom is dry (underneath)
Any one else with a newer Dyna experience this?
Probably just a gasket and a ton of labor I'm thinking.
I know the old saying that "all hd's leak oil"
I thought that it would at least take more than a few years to start.
It's not like a pool of oil or anything, but it's definitely oil.
Bike's still under warranty, so I'm not too concerned.
Any responses would be greatly appreciated.
Thanx
-J
Old May 10, 2007 | 12:26 AM
WdGldDave's Avatar
WdGldDave
Default RE: Need Help! Wide Glide leaking Oil
It will probably be an easy fix. Just bring it in if it's still under warranty. It would be a pisser if you have to fix it yourself (or pay for it) when the warranty expires. Could you post a pic? I'm curious about where it is leaking.
Old May 10, 2007 | 12:36 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Take it in right away.
Old May 10, 2007 | 01:31 AM
mud's Avatar
mud
dizzy, all HDs do not leak oil - that is an OLD saying.
If your 06 leaks any oil at all, I would be corncerned.
These newer machines are so well engineered, sophisticated gasketry,
precision machine work on all the fitup, seals are two three steps above high tech,
etc etc.
They do not leak - unless - there is a problem.
The issue you describe has been discussed here before -
in the last week or maybe two, I would say.
The way I read your posting, pic below is the issue.
If so, this is not a leak.
mud
ORIGINAL: jdizzie
So....
Thanx
-J
Old May 10, 2007 | 02:29 AM
mtnlvr's Avatar
mtnlvr
ORIGINAL: mudpuddle
.....These newer machines are so well engineered, sophisticated gasketry,
etc etc......
HA HA HA HA HA HA HA
Old May 10, 2007 | 11:21 PM
mud's Avatar
mud
ORIGINAL: mtnlvr
ORIGINAL: mudpuddle
etc etc......
mtnlvr, are you laughing because you dispute that statement??
I have never seen a drop of oil under my 06 dyna, for that matter,
I haven't seen a single drop of oil under any 06-07 dyna.
I've examined many of the seals, gasketry, and fasteners on these machines,
and they are way good.
What are you ridin??
mud
Old May 11, 2007 | 12:50 AM
mtnlvr's Avatar
mtnlvr
Yeah...I'm laughing at that statement. The first part of that statement actually.
Is that why there seem to be so many people having problems with their 05, 06 and 07's? (And I'm not talking about oil leaks...the EVO fixed those pesky leaks.)
FYI...I ride a 98 WG. And even though I do love it as well as the others I have ridden, (I'm gonna get flamed for this) Harley's are engineered near as well as the majority of the other makes out there. Sure...they've done a couple different things from their previous rides, but there's not a whole lot of new technology when you compare them to the "rice burners" of today.
Long live Honda!
Old May 11, 2007 | 03:22 AM
jdizzie's Avatar
jdizzie
mud,
the oil's actually leaking from the seam to the right of the spot on your picture.
I talked to my dealer today, i had to make an appointment to have the recall on my bars done,
they said that they'd look at it when I bring it in.
He didn't seem very concerned.
I'm confident that if there's a problem, they'll address it.
I wiped the spot down, took her for a burn, and when I got it home there wasn't a problem. (more oil)
i got to check it again tomorrow.
mtnlvr,
don't ge me wrong...
....i love hondas........
.......my lawnmower's a honda, and it rips!!
Old May 11, 2007 | 04:04 AM
atco's Avatar
atco
I'd say it's more an cosmetic problem...both my 2003 FXD had and 2002 FXDWG still has the leak but on black engine it won't disturb me anymore...
harleyjames123
Sep 10, 2024 12:05 PM
thewoozel666
Jul 1, 2015 12:15 PM
trackadaptor
Mar 17, 2008 02:04 PM
soft 02
Jun 26, 2007 12:08 AM
Animal494
May 22, 2007 11:11 AM
