Find a 2010 - 2013 Wide Gide with ABS with 20,000 or less miles for about 10 grand. You won't be sorry. Go to a dealer and ride a '14 or '15 Wide Glide. Same bike.
Wouldn't it be rather hard to find a 2010 with ABS?
Not me, the one thing I dislike about my Wideglide is the rear fender. Would love to change over to a Switchback rear fender.
I changed so much more than the rear fender....
FXDX front end
19" front wheel, dual disc.
14" T-bars with gauges up on top.
FXR gas tank/dash setup.
Moved key switch from the tank to the frame.
The bike is now for all intents and purposes an FXDX with 32 degrees of rake rather than 28 degrees of rake.
Much more stable at high speed on the highway.
I absolutely love how WGs look but the rake and thin from tire I found love me less then I love them. Maybe I'll go test ride the 07 Street Bob that they are selling for $6k. Similar look but less rake.
I'm running a 90/90 21 Pirelli on the front which is a little taller than the stock 80/90 21. Probably doesn't make a huge difference but I'm happy with it. The only issue I've had with that skinny tire is hitting an object like a rock in a turn. Scare the bejeezus out of you if you're not careful.
Perki48, I think you're right about ABS first WG option on a '12. I'm a big fan of it though. I've had a couple emergency situations crop up where I know the ABS helped big time. It's very much worth searching for a bike that has it.
