.3 miles, already issues. Check engine
Old Feb 26, 2016 | 09:40 AM
Uncle Larry's Avatar
Uncle Larry
I don't get it .... you ( OP ) "fiddle" with the scooter and then it doesn't function correctly and it's the dealers fault? Did I miss something here?
Old Feb 26, 2016 | 09:46 AM
emperor wurm's Avatar
emperor wurm
did you start the bike before moving the controls?
Old Feb 26, 2016 | 09:49 AM
Mxdad's Avatar
Mxdad
The way I understand is the dealer delivered the bike when the poster was not home. He slightly rotated the controls on the bars to position them to his liking (not uncommon) when he tried to start it there were issues.
If he had done some major work to the bike I would understand your question, but rotating the controls on the bars is no big deal and should not have affected anything
Old Feb 26, 2016 | 09:55 AM
Rollcage's Avatar
Rollcage
This is correct, by no means would I consider what I did something that could warrant a check engine light and no start.
Old Feb 26, 2016 | 09:56 AM
Rollcage's Avatar
Rollcage
It was started earlier in the day at the dealer, before transport, and before being out in 20 degree weather for a bit.
Then started at home. It was started after controls moved with signal issue, then started later with check engine light, then lastly with no start at all. no "tinkering in between last two starts (or attempts as of right now)
Old Feb 26, 2016 | 10:02 AM
Uncle Larry
I check all wiring going to controls, but I'm not an idiot, all I did was a slight rotation of grips, and try again ... I'm not trying to bust your ***** here ... You didn't "rotate" the grips, you rotated the complete control assy's which house the switch and wires. It's very likely that you pinched, pulled or twisted a wire located in the assy.
Old Feb 26, 2016 | 10:09 AM
Rollcage's Avatar
Rollcage
I know exactly what you mean. This was my initial fear, but it was pretty straight forward, and I did go back and check. I work on electrical equipment all day for a living, and completely subscribe to the theory of.... I just worked on X, and now something that has to do with X, isn't working.
Part of the reason for the thread, was to see if anyone had input on something related to moving the controls slightly, has the potential to cause these symptoms. I could see maybe the signal not working, and possibly even the no start, (BTW opposite side controls) but the check engine light, that one kinda stumped me.
And by no means busting my *****, I have thick skin, and came here for the input. I appreciate anyone who will give me any advice. I learned in my very first post (2 days ago) that I need to be prepared for the occasional lashing around here. It adds character
Old Feb 26, 2016 | 10:23 AM
Jackie Paper's Avatar
Jackie Paper
There is freedom in the cable coming to the control? If so loosening the control just enough to rotate it will hurt nothing. If they want you to take battery out, I would just loosen it, rotate the clamps slightly and resnug and put a maintenance charger on it for TWO days. Harley's is a little pricey but lights on informative. The Bell one at Walmart for half the price is just as good. I have both. No full size charger and then check the voltage .
They probably had the alarm set and it ran the whole trailer ride and sitting a month at a dealer can run a battery down if it's never been completely charged..
My info for battery if you do not understand charge system.....
Rev. 111015
Some electrical 101 and a little more..
Remember, the best made brand new battery that has been on a maintenance charger for 3 days that has a loose or bad connection is no better then a boat anchor with a loose rope. The connection can get loose after one ride if the battery is not anchored and the wires are short and get tugged in a direction that can unscrew the bolts.
After a good 24+ hour maintenance low amperage charge, with the charge light in the solid green and the battery has set about 24 hours off charge, voltage should be about 12.8 volts.
12.8 = full charged
12.6 = 75% charged
12.3 = 50% charged (Lot of new modern cars with system protection will not even click at this point but will have good headlight beams showing)
12.0 =25% charged
Always check both the terminals at the battery lead and also at the terminal on the wire. That helps to verify connection. With a DC volt meter (one that has a feature to lock high and low reading is best) hooked across the battery terminals and reading 12.8 or so, crank motor and while its cranking it should not drop below about 9.6 volts and as soon as it starts and throttled up to 2000 rpm, voltage should read around 14.8 volts. The 2000 rpm is the bench mark standard. Ignore idle output. Ignore output above 2000rpm unless it exceeds 14.9 volts. That is a sure indication that regulator is bad.
The crank check shows a rough check of the reserve amperage capacity of the battery while cranking with a 150-200 amp load on it. The 14.8 shows a good alternator and if you leave it on a while as the regulatory will drop the voltage a little showing itself working. However, with the lights and stuff always on, it will never drop back much. If you have a lot of options, most modern bikes will not show 14.8 charging volts at idle but stock newer bikes will be close. Older bikes with lower amperage output not so much. However, 2000 rpm is the bench mark for the standard 14.8 volts.
If you think battery is good and something is draining it sitting, now would be a good time to check for drain problems. Go to Harbor Freight and get you a AC/DC meter for under $25 or so. http://www.harborfreight.com/ac-dc-d...ter-37772.html Make sure it has DC amps draw, DC voltage, resistance and AC voltage. Key off. Remove the negative cable off the battery. Set meter on DC amps. Hook the meter lead to cable and the other to battery. How many milliamps (mA) is it drawing? It should be no more then 6 mA which is the ECM (1), speedometer (1), tac,TSSM (1),HFSM (1) and voltage regulator (1)
When a battery wears out, a good charge will show fairly good voltage, but the battery can still have very low amperage capacity which will show in the crude crank test above, but it really should be checked after a good charge by removing it from bike and getting a free check at a place like AutoZone that has a fancy load meter check that gives you a print out of the battery health. Battery MUST BE CHARGED to check it. Be sure they set their meter to correct cold cranking amperage stated on the battery. Never charge the AGM absorbed glass mat battery with a regular car battery charger unless it is a newer one that says safe with this type of battery. Also, by taking battery out you now know you have good connections. Vibration tends to loosen the connections or a little corrosion will prevent charging or cause starting problems. Be forwarned, these checks quite often are incorrect due to the low amperage of these small batteries and junk checking equipment. If bike is charging , no load on battery when key is off and you are still having problems…REPLACE THE BATTERY. If battery is more then 3-4 years old.. REPLACE THE BATTERY.
Using the maintenance charger can get more years from a battery but be careful here. You do not want the last start 5 miles from home. If it still grunts when you first hit starter or kicks back with a bang, replace it. After a few years, charge and pull battery and have it checked for cold cranking amperage ever spring. Even then, if it grunts most ever start, I would replace it. Most battery checkers at AutoZone and places like that do not do really well on the low amperage setting on small batteries. Not sure why but they tend to say they are OK when they are weak. If they have one that fits your bike, Wal-Mart's AGM absorbed glass mat battery is just as good as any for one third to half the money of a Harley Battery. Do not put an old fashion one with vent tubes on a modern TC Harley. Do not jump, push start or run bike with a half dead battery except in a real emergency. If a bike battery is down and you jump it, throwing all that amps to it from a big car battery especially one that is running can wreck a bike regulator or charging system. Charging a worn out battery can kill alternator stator or the voltage regulator or both. Probably ending in a big dollar repair in parts alone.
It is also a good idea to always check your battery at 2000 RPM with your meter set to AC. If by chance, the regulator goes bad, sometimes it will let AC come thru. That is a sure sign of a bad regulator. Older 2 wire stators have a single phase output while the newer stators with 3 wires have a 3 phase output. The 3 phase system provides a more consistent and higher current output to the voltage regulator. The voltage regulator takes the AC from the alternator, rectifies it to DC and limits the voltage level to the battery depending on the voltage reading it gets back from the battery.
Also remember, when starting a Harley, hit the starter and hold it in till it is firing on both cylinders and running before letting up. If you let up before it’s running, quiet often, it actually take an FI motor longer to start. There is a fraction of a second more for a long stroke Harley then a multi-cylinder car for it to get going. If you do not do this, it will kick back with a bang, sneeze thru the intake or crank a lot longer the second time or shame on you the third time. Also, if you have a habit of doing this, the starter solenoid switch contact will only have half the life it could. You cannot hurt the starter. The starter gear has a sprag clutch. There are drive pins in it that as the gas motor catches and run, it outruns the starter motor drive and disengages it from the electric motor. If you hold it in a little too long and listen carefully, you will hear the sprag clutch run up the ramps and slip. Makes a sizzle hum. This will show you your starter sprag clutch is OK.
Old Feb 26, 2016 | 10:36 AM
lionsm13's Avatar
lionsm13
Trade it in.
Old Feb 26, 2016 | 10:39 AM
Rollcage's Avatar
Rollcage
Originally Posted by lionsm13
Trade it in.
Exactly!!!
Street Glide time
