Help Seat question
Old Mar 2, 2016 | 11:53 AM
nevil's Avatar
nevil
You could try carefully touching up those studs with some matte black paint and a small brush. They will blend in better, if that's what you want.
Old Mar 2, 2016 | 11:59 AM
tcarson84's Avatar
tcarson84
Thanks for idea, not sure yet but i think i kinda like them. I mean i wouldnt have bought the seat with them if they had one without but now that its on the bike i think it looks pretty good. I'm just happy its going to work. I need to do some grinding and drilling on the back mounting bracket but i like it. Someone was saying it would scratch my fender i had an idea for that, when i was growing up I shot bows and we had this material called mole skin, its basically felt that has a sticky substance on one side. Do you think i could line bottom of seat with that? It did not come with the clear fender protector
Old Mar 2, 2016 | 12:10 PM
04FXDI's Avatar
04FXDI
Do you have a part # for that seat?
Old Mar 2, 2016 | 12:13 PM
tcarson84's Avatar
tcarson84
Originally Posted by 04FXDI
NO. Go to the dealer and order a seat tab for a Super Glide, it's like 12 or 13 bux. Those seats are pretty much the same for the FXDWG & FXDI fenders, just the rear tab is different.
Well i used the tab from my stock seat and its still too long. Are the superglide tabs different? I think with a dremel and drill i should be alright shouldn't be too hard if i mess up bracket just order new like you said only 13 bucks
Old Mar 2, 2016 | 12:14 PM
multihdrdr's Avatar
multihdrdr
FWIW, typically your seat fitment is 1996-2003 FXD. Typically (depending on seat manufacturer) FXDWG wideglide is not included. It has the rear mounting hole farther back on the fender as you've found out, but all other features are the same
Old Mar 2, 2016 | 12:30 PM
cggorman's Avatar
cggorman
Which seat?
Old Mar 2, 2016 | 12:37 PM
tcarson84's Avatar
tcarson84
Well i tried calling Saddlemen and there was a part number on the box but that said it was not right number. But its old seat they dont make anymore so not sure how to come up with it. Its called saddlemen drifter seat
Old Mar 2, 2016 | 12:39 PM
04FXDI's Avatar
04FXDI
Sorry bro was TT the OP
Originally Posted by cggorman
Which seat?
Old Mar 2, 2016 | 12:41 PM
tcarson84's Avatar
tcarson84
does anybody have any old parts catalogs or know if they have older ones online somewhere
Old Mar 2, 2016 | 12:42 PM
04FXDI's Avatar
04FXDI
I got ya, my 04 Super Glide came with the Wide Glide rear fender, (original owner swapped it) so in order to use the original seat I had to purchase the longer tab. I only run the original seat when I take my daughter for a ride, mostly I run the Tripper Solo or the Profiler Gel. Its a toss up and depends where Im going.
