Not sure what model you have, but my 13122J RR has a piece if metal running vertically at the very end of the baffle. I just put an old work glove on, hooked that with my finger, and twisted while I pulled. Mine had about 3500 miles on the pipe when I pulled. A little stiff, but it finally came out. I would imagine you could grab that piece of metal with a vice grip or channel locks if needed.
I am in a somewhat same spot, but I cannot get the exhaust tip to come of...so that I can TRY to get the baffle out...
My system is pretty much brand new.
Twist and pull action is probably your best bet. I would recommend that you take the megaphone off the header pipes if the system is still on your bike... You don't want to put a bunch of pressure on the mounting brackets, bolts, or heads.
This baffle in the video doe not have the cross bar at the end of the Bassani, but you can probably do something like this of you still can't get the baffle out.
