Stage 1 map
Old Mar 20, 2016 | 08:29 PM
04FXDI's Avatar
04FXDI
I pulled the new plugs a few hundred miles after I installed them just to take a look...they were fine. I don't think the bike runs bad at all, from round town to cranking up the highway she hasn't skipped a beat.
But heres another question....go easy guys this is my first EFI, always ran carbs as a kid. If I decide to goto a 2 into 1 like a Bassani Road Rage, can installing a Fuel Moto Micro Tuner do the trick if I give them my load out so they can program it? Or do I need more?
thanks.
Old Mar 20, 2016 | 10:52 PM
Tfree's Avatar
Tfree
Did that mod and love it . The micro worked great right out of the box with the Bassani RR 2/1..don t think you ll be disappointed .Also did the Kuryakin Velociprator to complete the package .
Old Mar 20, 2016 | 11:15 PM
NORTY FLATZ's Avatar
NORTY FLATZ
To get that "last 10%" you'll need to visit a dyno. The tech better know what they're doing too.
Old Mar 21, 2016 | 09:11 AM
04FXDI's Avatar
04FXDI
Does the Moto Fuel Tuner override the HD Stage 1?
Old Mar 21, 2016 | 11:06 AM
JohnMn's Avatar
JohnMn
I'm not sure if "override" is the correct term, but Yes the tuner will make the injectors squirt the right amount of fuel at the right time throughout throttle range.
You tell Fuelmoto what bike and engine you have and the parts you've used for the modification and they preload the canned map that suites the mod's best.
You can always squeeze a little more out with a $400 dyno tune but the neat thing about Fuelmoto is they offer you lifetime support.
Old Mar 21, 2016 | 11:43 AM
04FXDI's Avatar
04FXDI
Thanks JohnMn, I just emailed FM and they practically said the same thing, the micro will take over and make the corrections to the map needed, I won't have to delete or uninstall the HD Stage 1 map. For an exhaust and a/c upgrade I'm not sure I'll do a fuel Dyno tune unless I can find a reputable shop. Not really sure of the overall gains it would provide.
Old Mar 22, 2016 | 11:16 AM
JohnMn's Avatar
JohnMn
I can't justify a Dyno tune either. There's 3 local shops that dyno all between $375-400, if I went further then Stage 1 I would.
I'd give'm 250,, but for the gain 400 is just too much.
I mean I get it, they have hours involved in a tune. Maybe someday but it's not high on the list
Old Mar 22, 2016 | 07:14 PM
Stiggy's Avatar
Stiggy
Unless my bike had some glitch, a low spot, or stutter or some other quirk that was noticeable in every day operation, I couldn't justify the $400 to have some guy put a stress on my motor and drive train just to eek out a few extra HP that I don't use anyway with his dyno.
My bike has had several exhaust systems (last 3 were 2 into 1's) and the bike just runs as nicely as it ever has. The plugs 20,000 (?) miles on them burn a nice gray/tan color and there has never been any heat issues with a '00 anyway.
So if it aint' broke.....
Old Mar 22, 2016 | 07:47 PM
04FXDI's Avatar
04FXDI
We taking a carb on your 2000?
Old Mar 23, 2016 | 04:24 AM
Stiggy's Avatar
Stiggy
Magneti Marelli fuel injection (the first system HD used from '96 to early '02.)
95" Stage II 'big bore' and came that way from the factory.
tajar66
Jan 25, 2019 12:08 PM
troop
Apr 1, 2010 10:01 PM
dlwilson72
Aug 26, 2008 07:42 PM
crackercap
Mar 20, 2008 01:09 PM
cruiser85257
Feb 3, 2008 08:54 PM
