Stainless Bassani Installed...
Old Mar 22, 2016 | 07:04 PM
F86's Avatar
F86
Default Stainless Bassani Installed...
Today's project: Ditch the old chrome drag pipes, install my new Bassani Road Rage 3... I love it! It's made really nicely, it sounds great, the bike pulls strong... Next step, back to the dyno tuner to check out carb jetting.
Attached Thumbnails Stainless Bassani Installed...-img_20160322_185045.jpg   Stainless Bassani Installed...-img_20160322_185130.jpg
Old Mar 22, 2016 | 07:24 PM
F86's Avatar
F86
I ordered the pipe from Revzilla, and their customer service was really good (as always, I order from them a lot). Before the RR3 was released, I had ordered a black RR2, which I fortunately never got around to installing. Once the RR3 was released, Revzilla let me exchange the first pipe, even though more than 2 months had gone by. Both Bassani pipes were packaged really nicely, and arrived without any damage. The stainless steel pipe is noticeably lighter, partly due to the lack of full-length heat shields. Installation was pretty straight forward, although I had to shim the muffler bracket out slightly to fit my FXDX properly (the longer shocks put the bracket right against the swingarm, rather than right under it. A thick lock washer under each mounting point provided enough lateral clearance). The TIG welds are pretty nice, the bends are very nice, the megaphone has a nice brushed finish. Soundwise, I would describe it as raspier than the drag pipes. It idles at about the same volume as the drag pipes, but as the RPMs rise past 3 grand it really wakes up and sounds great.
I'm very happy with this pipe!
Attached Thumbnails Stainless Bassani Installed...-img_20160322_200619.jpg   Stainless Bassani Installed...-img_20160322_200748.jpg   Stainless Bassani Installed...-img_20160322_200912.jpg
Old Mar 22, 2016 | 07:43 PM
cerelious's Avatar
cerelious
That looks pretty sweet! Any chance of a sound clip after the dyno?
Old Mar 22, 2016 | 08:15 PM
tlminh's Avatar
tlminh
How is it riding with such limited heatshield?
Old Mar 22, 2016 | 08:24 PM
F86's Avatar
F86
I'll definitely try!
Old Mar 22, 2016 | 08:26 PM
F86's Avatar
F86
It was a complete non issue for me. The heat shield doesn't come installed, and it's held in place with a hose clamp which allows for some adjustment. I just sat on the bike and put it where my leg was closest to the pipe. I wasn't aware of any heat while riding.
Old Mar 22, 2016 | 09:22 PM
izzyryder's Avatar
izzyryder
Thanks for posting this. Bike looks good..
Old Mar 22, 2016 | 10:11 PM
fxdlx's Avatar
fxdlx
You need more back pressure if you wanna really wake up the mid range. Go to the auto parts store, buy a 2"OD X 1 1/2 ID exhaust reducer. Stick that in your muffler inlet. Fat end upstream.
Old Mar 23, 2016 | 09:50 AM
Warp Factor's Avatar
Warp Factor
Looks like you lost quite a bit of cornering clearance, compared to the staggered duals.
Old Mar 23, 2016 | 10:41 AM
Twospot's Avatar
Twospot
Looks sweet! I have a black one in the box waiting to be installed.
