Loctite on fairing bolts
Old Mar 23, 2016 | 01:05 PM
shekmark's Avatar
shekmark
Default Loctite on fairing bolts
I'm installing a HD 1/4 fairing with Bung King and HD quick release. Should I be using Loctite on all these bolts? Thanks
Old Mar 23, 2016 | 01:12 PM
Suede Blue Man's Avatar
Suede Blue Man
Use nylock nuts and you don't have to, clean and simple.
Old Mar 23, 2016 | 02:13 PM
enodrano's Avatar
enodrano
I would use Loctite on all bolts and screws on a motorcycle due to the excessive vibrations associated with it. Lock nuts can help but that is only if a nut is present. A tube of Loctite in a saddlebag or toolbox is a much simpler solution. Plus you don't have to go out and find the right sized lock nuts. Just remember, Loctite comes in different flavors. Blue is for bolts and screws you want to be able to remove again and Red is for ones you won't remove again.
Old Mar 23, 2016 | 02:23 PM
shekmark's Avatar
shekmark
Thanks!
Greg Di
2014-2024 Touring Models
Sep 5, 2021 10:28 AM
gunslingersnation
Audio Systems
17
May 16, 2019 02:37 PM
CT-Bagger
Nov 13, 2010 07:22 PM
aroacha5446
May 29, 2010 12:32 PM
anubisss
Oct 7, 2006 02:33 PM
