Upgrading brakes - looking for recommendations
Any suggestions?
Sorry...
But seriously... A good sintered brake pad (like an EBC) will help braking performance. Stainless lines (like Spiegler or Goodridge) will help lever feel (but not overall stopping ability). Flushing your fluid (if it's never been done) may help brake feel as well.
No reason to mess with the rotor if it's not beat.
I went down the same path as you are, I wanted more braking performance from the front brake but didn't want a dual conversion or different calipers. I've already upgraded the front suspension and went to Lyndall Z+ brake pads front and rear; I've always liked the Lyndall pads, no dust. For the next step I opted for the Arlen Ness Big Brake rotor and Goodridge ebony braided brake lines. Along with the new Lyndall Gold Plus pads I do believe I'll increase my front braking performance even further; if I could just get a quiet afternoon to install everything
If you go the Ness Big Brake route, it's important to get the right kit for your year of Dyna - HD changed the front discs to 11.8" from 11.5" in 2006 or thereabouts, by simply moving the cast caliper lugs on the fork sllder outboard a quarter inch. Ness initially didn't know about the change (make of that what you will!) and sold a kit for "dynas" irrespective of their model year. On the later bikes it located the pads a quarter inch outboard of where it should be over the disc friction surface.
Ness have now fixed the issue, and kit 02-972 fits 2006-wire wheeled Street Bobs etc which ship with the 11.8" discs. But note, virtually no-one (not even Ness themselves!) lists the part on their website, so you'll need to specify that part when you contact them.
As to its performance, I'm very happy with the distinct improvement it's made. more braking for less effort at the lever and, more importantly, I can now bring the bike to the edge of controlled lockup without that numb-spongy deathgrip lack-of-feeling of the standard set-up.
That's all.
Wearing the dumbass hat tonight, sorry about that...
Check out this thread: https://www.hdforums.com/forum/dyna-...witchback.html
EBC Contour Cut front and rear rotors
Lyndall Gold+ Pads
Goodridge black wrapped stainless lines
Diamond Engineering 12 point bolts
honestly, just changing your fluid out, a good bleed, and adding some $40 lydall z+ pads could net you some quick gains.
