Found a local deal on craigslist. A guy is selling a D&D Boarzilla in pretty good shape off a 2007 wideglide. I believe the only issue on my 2014 street bob would be the 02 bungs just hoping someone could verify that im correct on this before i jump on the deal. I know in 2012 they went from 18mm to 12mm bungs but aside from that will it fit ?
Yes, should fit. I bought a brand new D&D Fat Cat exhaust with the 18mm bungs(pre 2012) and installed them on my 2012. I did this because I have the Power Vision wide band 18mm sensors.
yea the fuel moto micro tuner doesnt use them so i figure i could just plug them til i get PCV
So now that fitment is established anyone run these pipes ? How do they compare with other 2 into 1 exhaust? looking to gain some power over short shots i have. Would thunderheader or bassani be a better option or do these stack up pretty closely?
Probably tired of hearing from me, I am sure others will jump in...
The Boarzilla is for big builds, 117" and up, so unless that is your situation, I would pass.
Practically any new set of pipes will out perform short shots, they do look cool though!
In general, 2 into 1, stepped headers, and longer = best performance. A ton of good choices, but I am a D&D fan, Fat Cat or Bob Cat with louvered baffle is a great choice.
Practically any new set of pipes will out perform shot shots, they do look cool though!
Hey if you got the knowledge to help and answer my questions its always appreciated ha ha thank you. I'm actually wrong on the pipe it is a fat cat. Might go ahead and make the deal then......wish it was black or even stainless but for 200 bucks i cant complain
Is the Boarzilla basically a FatCat with bigger diameter pipes?
Yes, Boarzilla is 1-7/8" & steps to 2" whereas the Fat Cat is 1-3/4" & steps to 1-7/8". Like Pilot mentioned the Borzilla is good on big motor builds and installing it on a stock 96 or 103, even my 106, would probably rob power where you need the back pressure.
