cam chain tentsioners
Old Apr 23, 2016 | 09:01 AM
bryanb's Avatar
bryanb
Stage I
Default cam chain tentsioners
Hi Everyone
I Bought a 2003 Dyna last summer and noticed at the end of the season the engine was getting noisy in the lower end. Didi some research and figured it was the cam chain tensioners as my bike has 45K on it. Sure enough pulled timing cover off and both inner and outer were worn out. I was going to put new bearings in as well replacing the rear cam with a roller bearing. I looked and it already has one. Did the stock bikes ever come with a rear roller bearing or can I take it form this it has been serviced at least once before?
Thanks Bryan
Old Apr 23, 2016 | 01:10 PM
CLukens's Avatar
CLukens
6th Gear
At 45k there is a good chance they were done once already
Old Apr 23, 2016 | 01:14 PM
Campy Roadie's Avatar
Campy Roadie
Stock the bike came with a ball bearing on the outside of the front cam and roller bearing on the outside of the rear cam.
Search my username for posts. I just posted in a tensioner thread where a lot of this is covered.
Old Apr 24, 2016 | 01:56 AM
Spanners39's Avatar
Spanners39
Originally Posted by bryanb
Hi Everyone
Thanks Bryan
1999 and 2000 came with ball bearing on the outside of the rear cam....2001 on has roller as stock.
Old Apr 24, 2016 | 03:39 AM
Campy Roadie
Correct
1999 and early 2000 models had a ball bearing outer rear cam bearing that caused some failures. Don't worry OP, that change to a roller bearing happened in 2000, your 2003 undoubtedly came stock with a rear outer roller bearing.
GJSchultz
Jun 9, 2016 02:46 PM
superderrick
Engine Mechanical Topics
Oct 5, 2014 10:38 AM
Mikes01deuce
Jan 1, 2013 01:56 PM
MarkM
Jun 10, 2009 05:25 PM
Haywired
Apr 27, 2009 04:05 AM
