Starter clutch or compensator
Old May 25, 2016 | 12:19 PM
  #41
Warp Factor's Avatar
Warp Factor
Originally Posted by Tommy C
When they fail the 5 rollers have flat spots worn into them & the center shaft is worn through the case hardening. I worked at an auto electric rebuilding shop for 19 years & saw many bad starter clutches from Harley starters.
Will this problem be temperature sensitive, only showing up when the engine is warm?
Old May 25, 2016 | 12:34 PM
  #42
soft 02's Avatar
soft 02
Having replaced many sprag clutches including a few HD ones its my opinion that its the design HD chose to use that makes them more prone to failure than the aftermarket ones. HD uses the spring backed over run type as opposed to the all roller type that All ***** and others use.
Old May 25, 2016 | 01:09 PM
  #43
Tommy C's Avatar
Tommy C
Hot starts were more of an issue due to lifter bleed down & heat soak as the engine is harder to turn over. It is important to start the bike with a closed throttle as well. An open throttle fills the cylinder & make the starter work harder.
Old May 25, 2016 | 07:15 PM
  #44
Gearhead88's Avatar
Gearhead88
Most of the starter clutches I have changed could be turned either way , some would eventually grab .
The bottom line is , these are not well made and they fail commonly.
Older bikes seemed to have better starters in them . I started working at a dealership when Shovelheads were still being made , just left there in 2014.
Old May 30, 2016 | 01:35 PM
  #45
sarpeezy's Avatar
sarpeezy
Hey guys, opened it up today...figured id give you some updates...
Things look a lot better than I had originally imagined, dont know what i expected but i expected SOME shavings...
The teeth on the starter looks worn, but if you look online at brand new ones their teeth have the same thing towards the very tip.
So im a little lost here, nothing seems off, I tried to hit the starter a few times and it catches every time....few posts ago someone posted a video of their starter, and mine looks nothing like that..it catches every time.
The grinding noise combined with no ground teeth points more towards compensator but im not sure...ill take any input
Old May 30, 2016 | 01:50 PM
  #46
sarpeezy's Avatar
sarpeezy
I just realized I never checked the actual starter clutch, so im going to take that out tomorrow or next day and hopefully ill find some shavings in there.
The bike is still open, so if anyone has any ideas or wants any pictures, let me know!
Old May 30, 2016 | 03:19 PM
  #47
Jackie Paper's Avatar
Jackie Paper
It's your starter gear if it ever bangs going in since it does have some flat besides the normal bevel. However, that could be caused by it coming back out when it kicks and bangs. You would get this from a weak battery letting off the key too soon but like you said, you do not do this. What does the contacts on the starter solenoid look like? Is the mica insulation between the pickups on the armature commutator high?
Old May 30, 2016 | 03:54 PM
  #48
Tommy C's Avatar
Tommy C
If this was my bike I would have changed the starter clutch already & been out riding today. This isn't rocket science.....
Old May 30, 2016 | 06:03 PM
  #49
sarpeezy's Avatar
sarpeezy
Im doing this at my buddies garage, so I cant just go down and check it again but will take a look at it.
I dont know what a brand new one looks like, but what you are saying is the starter gear does not look normal?
Old May 30, 2016 | 06:47 PM
  #50
Jackie Paper
Front looks quite damaged in picture but that is not what is causing bang in the video. It sure has to be engaged to crank like that.
