Clutch Cable/Lever Free Play .. No Can Do ..HELP
Old Jun 11, 2016 | 08:59 PM
motorbikemike48's Avatar
motorbikemike48
Default Clutch Cable/Lever Free Play .. No Can Do ..HELP
ok .. my turn to tap into the experience of the forum .. as part of my laundry lists of mods .. i am in the middle of changing out the bars .. risers and levers on my 2015 FXDL .. bike sits on a bike jack and clutched fine when it rested there ..
i have the cable adjusted FULL OUT .. and i still have considerable tension at the lever .. where do i go from here to make it right .. (FYI .. i do have a manual .. didn't find fix) .. TIA
Old Jun 11, 2016 | 09:02 PM
QC's Avatar
QC
Set it on the ground and start over at the pushrod adjuster.
Old Jun 11, 2016 | 09:14 PM
motorbikemike48
Thanks .. will do .. gunna be a bit before that happens .. on the Pick Up list for now .. MBM48
Old Jun 11, 2016 | 09:17 PM
cggorman's Avatar
cggorman
Full out, meaning the cable sheath is as long as it can get, or as short as it can get? Longer (more threads showing) = tighter.
Might have to adjust the clutch itself. Simple. Its in the manual.
Old Jun 11, 2016 | 09:57 PM
JohnMn's Avatar
JohnMn
Yeah that's what got me too,, "full out" will remove all play from the lever,, turn it in man. And when you start getting close a 1/4 turn will make or break the sweet spot,,
Old Jun 11, 2016 | 10:07 PM
archergodwin's Avatar
archergodwin
Cable should be almost fully collapsed when adjusting the clutch pack. Once the push rod/release plate is adjusted in the clutch pack... then expand the clutch cable back out.
Old Jun 11, 2016 | 10:11 PM
Stiggy's Avatar
Stiggy
One thing they never tell you til it's too late: When the tension is loose on a clutch adjustment, never pull in the lever or you may very well 'flip the cam' under the clutch actuation cover on the right side of the bike where the cable enters the tranny case.
Kebo
Jun 7, 2012 03:16 PM
Badass67stang
Apr 30, 2011 04:49 PM
Sam D.
Jul 18, 2010 12:19 PM
dyna rider
Jun 30, 2010 08:56 PM
kylant
Sep 24, 2008 02:37 PM
