2005 FXDCI ignition switch
Old May 20, 2007 | 08:42 PM
Patch's Avatar
Patch
Default 2005 FXDCI ignition switch
I have a 2005 FXDCI with the ignition switch under the seat
does anyone know if I can replace the stock ignition switch with an ignition switch from the baggers with the switch on the tank console...this way I would not have to ride with the key in it
also a little easier at gasstops..I think it would look nice too????
Old May 20, 2007 | 09:48 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Default RE: 2005 FXDCI ignition switch
See if your dealer has a set of Softail tanks that you can measure the mounting holes on. I think they will be closer to fitting the Dyna frame than the touring tanks. The easiest conversion would be to swap tanks and all so you will be sure the mounts for the bracket will be there.
dave713
Oct 29, 2016 09:44 PM
FXD_noob
Nov 3, 2015 09:10 AM
Charlie588
Oct 5, 2012 11:12 AM
two tall
Apr 1, 2011 01:22 AM
kawsakimx6
Jul 12, 2007 01:01 AM
