2006 Super Glide custom...
Old Jul 5, 2016 | 08:03 PM
tnriverluver's Avatar
tnriverluver
Originally Posted by Blackstar
The front tire is worn and looks like some slight scalloping. Has sat for 2 -3 years. An older gentleman owned it but didn't use it much. He might need a complete going over. Thanks for the input...
Glenn
Look on the sidewall and find the manufacture date. Probably the original tires from 05. Any motorcycle tire over 5 y/o needs to be replaced and put in the trash!!!!
Old Jul 6, 2016 | 05:51 PM
Blackstar's Avatar
Blackstar
I'll check. Thanks.
Old Jul 6, 2016 | 08:43 PM
Deerslayer011's Avatar
Deerslayer011
2nd Gear
07 is the 1st year for E.F.I
Old Jul 6, 2016 | 09:59 PM
ackman1968's Avatar
ackman1968
No it isn't, 2006 Dyna's were all injected. If you look, you will find all the FX (Dyna series) model designations for 06 end with an "I", as in injected. They also had the first six speed, new cam plate and hydraulic tensioners and their share of issues!
Old Jul 6, 2016 | 10:20 PM
Deerslayer011
2nd Gear
Harley Davidson’s sportster motorcycle is the first Harley Davidson range of bikes which come with EFI installed. This started in the year 2007 itself. EFI is Electronic Fuel Infection, which comes as original Harley equipment in bikes like FLH, Buell’s, Dyna’s and Softails all offer EFI since the year 2007. An EFI was always an option since 1996 but technological changes and a concern for the environment has caused Harley to make advancements in the direction of producing bikes with EFI already installed.
Old Jul 7, 2016 | 05:31 PM
Blackstar's Avatar
Blackstar
So, does this '05 have the hydraulic tensioners that were giving problems? Are there any other issues that would concern the new owner? He really is a Noob to bikes.
Glenn
xbdonx
Jul 6, 2011 12:34 PM
Ultrasweet
Mar 31, 2009 11:03 PM
SIM
Oct 2, 2007 01:33 AM
Bear64
Jul 18, 2007 03:46 AM
OH Bob
Mar 6, 2006 01:59 PM
