I have an 07 St Bob....I'm going to install the front T/S on the forks..... I have the 49mm clamps.....Just looking for anyone that had a good time getting the wires down to the forks.....It appears the T/S wires come right out of both handlebar switches... That is not like the 05 softail standard my buddy drives.... All he had to do was unbolt them and just install them on the forks.......just cutting off access wire... Ok.....I need some help from anyone with an 06 or 07.....I guess that's the years that are different.... Thnaks.........
You have to remove the tank, and fish the wires out of the area behind the steering head. The rubber grommets pull out with a screwdriver. if you reach under the backbone, you can pull off the plastic cover. Then you pull the connectors out, and remove the wires from them. Then you need to route them through the t/s brackets, and back through the grommets into the connectors again. If this seems like a pain in the ***, its because it is. The easiest way to do it is to get some black shrinkwrap, and a soldering iron. It will save you alot of time.
"PAIN IN THE ***"
On my wifes I just bought new turn sigs,68.00 Zanotties. Cut the old ones off, Installed newpins on new Sigs, Left dead wires in handle bar harness until I do the New bars with Internal wireing,30 min tops, easy. Spent the 68.00 for new turn sigs 59.00 for Kury mounts and saved alot of time for rideing...
I knew someone out there must have done this with a new, stock internal wire, bike... This is pretty much what I suggested as well
