Lazarus Project: 2012
Old Oct 14, 2016 | 09:33 AM
  #511
multihdrdr's Avatar
multihdrdr
The effort made on installing the Tires is how "we" learn...now isn't it
Those wheels should look good installed.
Old Oct 14, 2016 | 09:46 AM
  #512
natedog_37's Avatar
natedog_37
Nice I really love though rims. I just want them in all Black.
Old Oct 14, 2016 | 12:04 PM
  #513
multihdrdr's Avatar
multihdrdr
C, maybe it's just the photo(s), but it appears the bearing is deeper on that pulley side after your bearing exchange. Did you notice if the bearing bore depths were different? and did you start the first bearing on the brake disc side or on this pulley side?
Before bearing changeout...
After bearing changeout...
Old Oct 14, 2016 | 12:23 PM
  #514
natedog_37's Avatar
natedog_37
I am thinking it is the lip making the bearing look wrong but I could be wrong
Old Oct 14, 2016 | 12:36 PM
  #515
TinCupChalice's Avatar
TinCupChalice
multihdrdr, a teachable moment
I've removed and installed wheel bearings multiple times but have never seated a bearing too deep. If a bearing is indeed seated too far what are your options? Can you use the bearing removal tool to pull the bearing back to proper depth or does the bearing need to be removed and replaced? I guess I'm asking if you should replace the bearings if you toast the install...
Forever a student...
Old Oct 14, 2016 | 01:03 PM
  #516
natedog_37's Avatar
natedog_37
Unless you beat the crap out of the bearing you should be able to use a puller and get it to where you want. "pulling it back out"
Once a bearing is dropped, or even hit hard they should be replaced.
Old Oct 14, 2016 | 01:36 PM
  #517
multihdrdr's Avatar
multihdrdr
"Forever a student..." as we all are...or should be
I try to learn something new every day...sometimes I fail, but trying to keep that in the minority
along the same lines posted above...
Technically, you would/should replace a bearing anytime you use one race+the ***** (or rollers,etc) to forcefully move the other race, such as during the wheel bearing removal process because you can't get to the outer race so the inner race+***** is used instead to remove bearing assy.
With that being said, if you used a slide-hammer (or hammer and drift) to remove or move the bearing...It's definitely time for a replacement. On the other hand using a typical puller like this Pit Posse, because it applies force (how much needed depends on "interference fit", time in housing/bore, etc), but not impacting force you probably could get away with it especially when considering it was a New "just installed" bearing with lubricated outer race/housing.
It has no doubt been done countless times before with no ill effects. You would have for judge yourself on case by case basis. Maybe even "Was it a $5 or $40 bearing?" comes into play
Old Oct 14, 2016 | 02:21 PM
  #518
natedog_37's Avatar
natedog_37
True putting a force on the race could damage it. Funny when i worked for a bearing company how many we would get back and they where shock the bearing was damaged because they dropped it.
Old Oct 14, 2016 | 06:23 PM
  #519
DeaD SpacE's Avatar
DeaD SpacE
Look up ZIP TIE tire mounting,works like a champ you can just push the tires on the rims.
Old Oct 14, 2016 | 11:05 PM
  #520
cvaria's Avatar
cvaria
Red face
Education.....
Thank you!
yes, it is in too deep... i will adjust the bearings... glad you caught it before i put the pulley back on. more Multihdrdr checks being written.
Hamfist is on the loose in my garage. ..... he also destroyed my front tire bead by leaving it stretched over the wheel lip all night. had to drive to daytona to get another tire..... because no shop in tallahassee, panama city, or j.ville had one. j&p cycles had one... 7.5 hrs later, having fought through biketoberfest, walking 1/2 mile with a tire because that radius of the building was reserved for bikes only...
i have a new front tire to mount (stupidity is expensive ).... fun times...
it was actually all positive... learned a lot plus a super dose of humility....
shop :"hey, did you know a rim guard was in your tire?"
me : "Yes... yes i did... i did that"
shop : "..."
shop :"you sure you want us to mount this tire with the bead torn up like this (pointing at rip and exposed wires)"
me : "F***!"
that kinda day...
at least i woke up this morning.
