nothing happens when i turn on the ignition
Old Aug 6, 2016 | 08:58 PM
McFlysD's Avatar
McFlysD
Default nothing happens when i turn on the ignition
Hello, I have an 05 fxdwgi with the 95ci motor, i've had it happen a handfull of times where i turn on the ignition and there is no power anywhere, no lights or buzzing, then when i turn it off and on it'll usually turn back on and start up just fine. It seems like it might just be a poor connection somewhere but im not very mechanically inclined when it comes to motorcycles because i've only owned it for 2 years now, any help would be great thank you
Old Aug 6, 2016 | 09:28 PM
jtarter's Avatar
jtarter
I would have to suspect faulty ignition switch contacts, or loose/dirty connections on the back of the switch. Do you have a manual?
Old Aug 6, 2016 | 09:29 PM
McFlysD's Avatar
McFlysD
just the one that comes with it, i dont have a service manual
Old Aug 6, 2016 | 10:10 PM
jtarter's Avatar
jtarter
I would suggest you get a service manual if you will be doing any of the work yourself. You said you are not too mechanically inclined. I might suggest finding a friend that is or a local Indy shop.
Old Aug 6, 2016 | 10:24 PM
QC's Avatar
QC
Here's a little how-to on cleaning your ignition switch. It's pretty simple.
Also clean the plug and receiver while you're in there.
https://www.hdforums.com/forum/softa...le-riding.html
Old Aug 7, 2016 | 01:23 AM
McFlysD's Avatar
McFlysD
thank you for the link to that! i'll try tearing into it later this week, i just had knee surgery last week and i'm getting close to being able to hop back on
Old Aug 7, 2016 | 12:57 PM
nevil's Avatar
nevil
The ignition switch is the most likely culprit, but a loose battery ground cable can give intermittent problems. Also check the connections at the battery.
jpooch00
2014-2024 Touring Models
20
Aug 4, 2016 09:25 AM
bigbush
Jun 29, 2015 11:40 AM
dulley
Mar 4, 2014 10:56 AM
Wally
Aug 19, 2012 11:30 PM
zoomie67
Mar 11, 2010 10:29 PM
