Fxdf rear wheel on '06 fxdb
Old Aug 10, 2016 | 02:19 PM
linewatch's Avatar
linewatch
Default Fxdf rear wheel on '06 fxdb
I know there is a lot of information on this. What I cannot find is would I be able to use the 1" spacer and bearings in the wheel and trim a little off the caliper/ mount and have it bolt in? Or will I need the 25mm axle, spacers, bearings, and two piece rear brake?
Thanks
Old Aug 10, 2016 | 02:53 PM
cvaria's Avatar
cvaria
Thanks
compare the rear components of the bikes by part number, adjust as needed.
http://www.stcharlesharleydavidson.c...partfinder.htm
Old Aug 10, 2016 | 05:50 PM
linewatch's Avatar
linewatch
thanks for that link i am sure it will come in handy. the part numbers match for the 08 and up but the 06 and 07 have the 1" axle so all the numbers do not match. i was hoping some one knew if the spacer in the axle would fit in the fatbob wheel. the fatbob information starts in 08 with the 25mm axle.
Old Aug 10, 2016 | 06:01 PM
cvaria's Avatar
cvaria
why not just get a spacer(s) of the same size [brake/pulley] in your 1" ID as opposed to working in the other direction?
the wizard will appear with the answer at some point, hold on
Old Aug 10, 2016 | 06:44 PM
linewatch's Avatar
linewatch
My goal is to know if my 1" ID spacer will fit in the fatbob wheel so I do not have to buy all the parts to fit the new wheel.
I hope I am being understood.
Old Aug 10, 2016 | 08:52 PM
multihdrdr's Avatar
multihdrdr
Your 06 center spacer sleeve will be too short for that 08 FXDF rear wheel that is designed for the narrower 25mm ID x 15mm wide bearings. You'll need to use the 08-later spacer sleeve.
Have you thought about the 1" bearings you want to use? Your 06 1" x 21mm will protrude slightly from the hubs so you have to trim the spacers. You can get aftermarket 1"x 15mm wide bearings and have a very slight spacer change (I think some say "screw it" with making that slight change) I vote for the superior long lasting 1" x 21mm
Old Aug 10, 2016 | 09:23 PM
cvaria's Avatar
cvaria
Old Aug 11, 2016 | 01:23 AM
linewatch's Avatar
linewatch
[QUOTE=multihdrdr;15403555]
So does that mean my '06 center spacer will still be too short if I use the 1"x21mm? Is it just the difference between the bearing widths or is it still too short?
Thanks for your help.
Old Aug 11, 2016 | 08:31 AM
multihdrdr's Avatar
multihdrdr
Too short no matter which bearings...it's the wheel that dictates the length (or bearing positioning on some models). Those sleeves are inexpensive $8-10 list.
Old Aug 12, 2016 | 05:48 AM
linewatch's Avatar
linewatch
OK thanks.
06 streetglide.
Apr 4, 2019 10:31 PM
Dresportster
Wheels/Tires
Feb 6, 2017 02:52 PM
abez
Wheels/Tires
Oct 31, 2016 03:15 PM
jakespade
Jun 12, 2013 06:47 PM
55bob
Nov 11, 2010 05:47 PM
