No start condition...HELP!!!
Old Sep 1, 2016 | 03:03 PM
larryb110's Avatar
larryb110
Another thing I have been wondering...as I haven't been able to get back out to work on the bike...I live in AZ and turn signals are not required so I have mine all removed. Will that cause an issue with trying to clear the security system if that ends up being the case.
Old Sep 1, 2016 | 04:00 PM
Synstars's Avatar
Synstars
If you ran the wires through the bars double check the diagram on the plugs to ensure that you made the proper installation into the plugs going to the ECM. If this is incorrect it could most certainly trigger security or false ignition putting the red key light on.
If you need assistance on here I'm sure someone can give you a picture of the wires going into the plug or find you a diagram.
Old Sep 1, 2016 | 06:12 PM
larryb110's Avatar
larryb110
Yeah I double checked all the connections and even ran a continuity check through all the switches and they are wired correctly
ghost183
Electrical/Lighting/Alarm
27
Jun 1, 2018 10:15 AM
Regulate08
Mar 23, 2016 05:26 PM
gwharley
Oct 26, 2015 09:08 AM
bigbearzfan
Mar 29, 2014 07:31 PM
CCNitro
Mar 28, 2010 03:20 PM
