Convert to Dual front dics with ABS
Got fork sliders from fat bob - don't see where machining will be needed. Based on what I read it was only fender fitting differently
Brake line - you can actually run second line from master using dual line banjo bolt - did it on sportster and it works awesome, some are saying better than splitter
Another tokiko adapter from SM and caliper off ebay
11/16 master from there as well
just did forks rebuild with cartridges - so only seals
I'll need is to swap wheel - my switchblade takes only one disk
Thinking between these two
Research is your friend... see post #46 in this thread: https://www.hdforums.com/forum/dyna-...eet-bob-5.html
Just trying to give you a heads up: Mike
Rodger has to make the same decision. Since he also won't be able get a matching dual disc front for his Switchblade rear wheel. Will he use a Low Rider wheel (like you show), which is close in design to the rear, but not a match or get 2 new wheels?
This is pretty much the standard condition when you use Fat Bob legs with mid glide trees. If your basing your build using the the article in Hot Bike: http://www.hotbikeweb.com/tech/doubl...ersion?image=0 Somehow they forgot mention the calipers were machined, its the only way this combination of parts works.
Bad HotBike...Bad
As far as the 11/16 M/C, I've had to dremel them to fit my wide glides. Nothing major. Just the little fork tab area the connect to the switch housing is too narrow and needs to be widened on the right side. Take a few seconds with the dremel. I didn't measure the difference either time i did it, sorry. the m/c's i used came from a 2001 road glide and a 2011 fat bob.
As far as the 11/16 M/C, I've had to dremel them to fit my wide glides. Nothing major. Just the little fork tab area the connect to the switch housing is too narrow and needs to be widened on the right side. Take a few seconds with the dremel. I did measure the difference either time i did it, sorry. the m/c's i used came from a 2001 road glide and a 2011 fat bob.
Double line from the Master won't work for the OP having ABS...although theoretically a person could probably double banjo the existing Left Caliper and run a jumper hose over to the New Right Cal. Probably a moot point though since HD has off the shelf parts to make this swap pretty routine.
I have also mentioned on this forum regarding that omission in their article along with not addressing the the different fender mounting dimensions
Bad HotBike...Bad
Thanks for the thoughts. Low rider will work as far as I am concerned. I just want duals( my bike is already abs single ) and if not a match will not bother me. I wish I had bought a LR but at the time of my purchase-2013, they had not come out. I have copied all the contructive posts to give to the shop. Hoping to make his job easier. At present I plan to buy my parts from Sturdyke unless the shop wants to use their own sources. Is there anyone out there that has done the conversion with ABS?
Roger
The limiting factor in braking is the front tire not the number of discs. Of course it takes less pressure to lock the front with dual discs and they will not heat up as fast under hard use like on a track. But they can not and will not stop the bike any faster than a single disc-period.
A well trained person can generate 0.9 G's of deceleration on any H-D cruiser with either system. There is a school in Calif. that does that training. The average student in that course starts out with 0.4 G's. Then at the end can do 0.9 G's.
I find it easier to modulate a single disc just due to the fact that it takes more pressure to achieve the force needed.
A properly setup bike with high quality dual discs and good suspension will stop WORLDS better than the average Harley. Anyone who's ever spent a fair amount of time on sport or performance bikes is generally appalled the first time they jump on a Harley and try to stop, and rightly so.
The whole Harley suspension/brake setup on most bikes is pure garbage. A proper setup doesn't just lock the front wheel faster, as some seem to believe. It provides the rider with way more feedback of what's actually happening between the bike and the road.
There's a reason pretty much every other motorcycle on the road has dual brakes (often Brembos), and a quality suspension. My old Dyna was like a Model T Ford compared to my Ducati, which can stop in an amazingly short distance from high speeds. If I tried that on my Dyna I would have been in a ditch for sure.
Most of us really enjoy swapping parts around and doing things to personalize a bike and make it into something special. But we should not be forced into replacing whole systems of the bike because they're unsafe and just generally rubbish. Harley doesn't do anything about it because they don't have to. They have a loyal customer base who willingly pays full price for a badly designed bike, then drops thousands more just making the bike ridable. In fact, they're counting on it.
http://www.krausmotorco.com/collecti...cts/nicks-dyna
Pretty much.
I finally found a local shop that claims it can convert to dual abs. A lot cheaper than buying a new Low Rider and setting it up. I love my Bob, and have it set up the way I want. It took me nearly 2 years of looking and installing. Now for the last step. Essentially I am converting to a LR, but at the time I purchased, they did not have the current model. The conversion will include a new wheel, disc,caliper, brake cylinder and possibly new fork. I am sure there is more.
I will be taking the bike into the shop in October. They seem very competent and knowledgable. But I still worry and hope they put their actions where their mouth is.
Will post the dealers name and results if it comes out well.
I would appreciate any thoughts and advise on the conversion.
Roger
Roger
