I have a 13 Street Bob with a 120R. I have never found it to have weak front brakes. Any HD that I have (22) with single rotors will lock the front brake with two fingers.
The limiting factor in braking is the front tire not the number of discs. Of course it takes less pressure to lock the front with dual discs and they will not heat up as fast under hard use like on a track. But they can not and will not stop the bike any faster than a single disc-period.
A well trained person can generate 0.9 G's of deceleration on any H-D cruiser with either system. There is a school in Calif. that does that training. The average student in that course starts out with 0.4 G's. Then at the end can do 0.9 G's.
I find it easier to modulate a single disc just due to the fact that it takes more pressure to achieve the force needed.
The point is not locking the wheel, but the way the brakes goes till the point of the wheel being locked, and with this I mean the braking curve.
Most harleys i've rode usually starts braking till a point where you can lock the wheel, i've test rode some sport/naked bikes with brembos and dual discs and HOLYBALLS how those things stops in comparison with my dyna, the brake curve is smoother and the feeling is far better, I mean you can get shot out of the bike if you don't firmly hold the handlebar.
A properly setup bike with high quality dual discs and good suspension will stop WORLDS better than the average Harley. Anyone who's ever spent a fair amount of time on sport or performance bikes is generally appalled the first time they jump on a Harley and try to stop, and rightly so.
The whole Harley suspension/brake setup on most bikes is pure garbage. A proper setup doesn't just lock the front wheel faster, as some seem to believe. It provides the rider with way more feedback of what's actually happening between the bike and the road.
There's a reason pretty much every other motorcycle on the road has dual brakes (often Brembos), and a quality suspension. My old Dyna was like a Model T Ford compared to my Ducati, which can stop in an amazingly short distance from high speeds. If I tried that on my Dyna I would have been in a ditch for sure.
Most of us really enjoy swapping parts around and doing things to personalize a bike and make it into something special. But we should not be forced into replacing whole systems of the bike because they're unsafe and just generally rubbish. Harley doesn't do anything about it because they don't have to. They have a loyal customer base who willingly pays full price for a badly designed bike, then drops thousands more just making the bike ridable. In fact, they're counting on it.
All is correct except for the fact that this guy as well as Kevin from Big Bear chopper purchased four sets of my complete forks that I designed, engineered, and sold in 2010. Kevin took my forks to a machinist and exactly replicated my trees with the exception of removing the front bar for cable management, putting a steering stem nut on the top of the tree, and changing the looks but retaining the exact location of the holes on the fork tubes, steering stem, and the general shape of my trees. That is where the engineering is. The caliper brackets were copied but made to look more like a single piece axle clamp but not the same material nor the same structural design I paid an engineer to design.
How to you feel about touting a few guys who do not have the talent to design a major concept than sell a piece as their own? I know as I am the only person who designed, veraciously tested, than produced and brought to market that design. Now that is the truth.
...with brembos and dual discs and HOLYBALLS how those things stops in comparison with my dyna, the brake curve is smoother and the feeling is far better, I mean you can get shot out of the bike if you don't firmly hold the handlebar.
Just my .02
You are correct it is called brake feedback. You must be able to feel what the tire and calipers are doing. There is a big difference between a top superbike rider (or any other class rider in asphalt motorcycle racing) than some Hog Member bouncing down the street and whose riding skills and experience are not on par as the aforementioned. You must know how far to push your bike and stop at that limit. A broom stick in the spokes will lock up a wheel, makes me laugh when I hear the
PHP Code:
"Any HD that I have (22) with single rotors will lock the front brake with two fingers"
Well this is it. Took my bike to the shop today. Hopefully will have it back in two weeks. Will report once completed.
Roger
All parts are ordered except for the wheel. They are back ordered till December. Well I guess another month won't be to bad. Once the get the wheel, the shop thinks it will only take a day to assemble. They claim they are now doing about one a month converting single abs discs to dual. They get the parts from a harley dealer.
See you all next month.
Roger
Roger
I wonder what ever happened here. I’m playing with the idea for my softail low rider and found this thread on a search. Shame it just ended w/o a follow up. Oh well, keep looking.
I wonder what ever happened here. Im playing with the idea for my softail low rider and found this thread on a search. Shame it just ended w/o a follow up. Oh well, keep looking.
The way you play musical bikes , why not just trade it in for the new low rider s.
No better here , it crossed my mind the same way when they came out with the first s. Tough choice considering the low rider you have now. Its looks like a great bike!
Well I have been complaining that without dual front rotors my 2013 Bob has very poor braking. Harley should be ashamed.
I finally found a local shop that claims it can convert to dual abs. A lot cheaper than buying a new Low Rider and setting it up. I love my Bob, and have it set up the way I want. It took me nearly 2 years of looking and installing. Now for the last step. Essentially I am converting to a LR, but at the time I purchased, they did not have the current model. The conversion will include a new wheel, disc,caliper, brake cylinder and possibly new fork. I am sure there is more.
I will be taking the bike into the shop in October. They seem very competent and knowledgable. But I still worry and hope they put their actions where their mouth is.
Will post the dealers name and results if it comes out well.
I would appreciate any thoughts and advise on the conversion.
Roger
Came out great. Like OEM. Shop did a great job. Slab Sides in Campbell Ca. Highly recommended. Had it done last year 2017. If I bought a new Street Bob Soft tail, I would have them do it again. Can't believe Harley can get away with one disc.
