Sputhe stabilizer question
Old Sep 16, 2016 | 12:18 AM
NorthWestern's Avatar
NorthWestern
Originally Posted by djorgensen3
I have increased the tire pressures but I have not done anything with steering neck bearings. It feels like I have a low rear tire. I don't ride with a tight grip. A lot of the time my hand is just resting on the grips with open fingers. The bike also pulls hard to the left if I let go of the bars. I absolutely cannot let go of the bars. It will not track straight. It has done this since I brought it home. I did check vertical alignment with a couple inclinometers on the frame and rotors and it is good. I haven't done a front to rear tracking alignment yet though. I also did not put any preload in when I installed the Positrac. The bike does track much better when the wife and I are riding somewhere. I did put one full turn of spring preload on the rear springs from stock just to help with load capacity when 2 up. I had the bike up to 120 mph the other day and it wiggles the whole time. It's kind of unnerving. I will say the Positrac helped a little but didn't eliminate the wiggle.
Yeah...that is nuts. I can no-hand it, no problem.
Old Sep 16, 2016 | 04:56 AM
Wide One.'s Avatar
Wide One.
I put a Positrac on my Wide Glide and it still had a wobble at higher speeds. I dropped in some Progressive cartridges to the front forks and no more wobble. 70/80/90mph and hands off the bars.
Old Sep 16, 2016 | 09:17 AM
cghorr01's Avatar
cghorr01
I do believe stock suspension in many cases tends to be the issue in conjunction with lateral powertrain movement.
Old Sep 16, 2016 | 09:35 AM
djorgensen3's Avatar
djorgensen3
Last night the wife and I took the bike to a bike night here in Phoenix. And as usual, the bike rode great. It tracked just fine with more weight on it. My front end is supposed to have at least one cartridge installed in it already. I am gonna try and check front to rear wheel tracking alignment here soon and see if it's good or not.
Old Sep 16, 2016 | 10:25 AM
djorgensen3
Sorry for jacking your thread OP....
Old Sep 18, 2016 | 12:32 AM
autonomos's Avatar
autonomos
2nd Gear
Yea, that's definitely not normal. Like most here, mine handles well. If it's pulling that hard when you take your hands off something ain't right. Might be a good idea to bring it to the dealer under warranty.
Iron lHorse
May 25, 2014 07:10 PM
'05Train
Oct 18, 2008 07:25 AM
ninetyzero
Dec 6, 2007 10:47 AM
mimo
Nov 29, 2006 05:16 PM
anubisss
Sep 22, 2006 10:58 PM
