Fork rebuild and many thanks
Old Sep 16, 2016 | 06:43 PM
cerelious's Avatar
cerelious
Default Fork rebuild and many thanks
Ok, I'll start with I have never done forks before, so this will be a rough documentation of my adventure, fun pics, and learning experience.
Decided to go with RaceTech straight rate Springs (1kg) and gold valve emulator. I'll post pics as I remember, and probably ask questions as I go.
So, to start, the kit. Love that it came with the PVC
Removed wheel and brake caliper. Noticed the brakes wearing uneven...
Replaced brakes. Removed forks, also decided to clean and repack stem bearings.
Major shout out once again to J&S Jacks. Some brothers came over to help/gang and they were impressed that I didn't have to strap it down. Also impressed that I could let my boy explore and not even worries that he may throw off the balance. Spreading the addiction to the next gen....
Old Sep 17, 2016 | 04:24 AM
stilup's Avatar
stilup
Scares me to see the boy comfortable around those cold parts.
When mt bike is on the lift no one is allowed near it.
Look , don;t touch.
Old Sep 17, 2016 | 06:29 AM
cvaria's Avatar
cvaria
Look , don;t touch.
no straps + baby?
bro.......
glad you got/getting your job done and are liking your j&s
here to help if needed...
Old Sep 17, 2016 | 08:22 AM
skinman13's Avatar
skinman13
I am also past the point where I need to rebuild my old worn-out front tubes, I just have not decided which way to go, back with OEM springs, restrictors, or progressive springs.
looking at that caliper, it looks like the top-left piston (looking at the photo) is extended further than the lower one. That could indicate that one of or all them are sticky...if I saw this on my ride, I would be rebuilding the caliper and checking caliper alignment with the disk after installing...ain't much work and rebuild kits are cheap. Bleeding is a bigger pita in my experience.
Old Sep 17, 2016 | 11:23 AM
NorthWestern's Avatar
NorthWestern
That J&S make you want to work on the bike, doesn't it??
F86
Aug 18, 2020 09:50 AM
Xxamiam
Jun 24, 2018 08:49 AM
abez
May 6, 2017 09:49 AM
chriswillrise
Sep 19, 2016 11:59 AM
gilmour68
Feb 22, 2009 10:59 AM
