Polishing fork sliders
Can someone please send a link to that thread?? I just got mike bike up on a jack and I'm ready to take off the wheel and get started.
Thanks in advance
I did mine couple years ago and it went like this: aircraft stripper from walmart to get the clearcoat off, 400,600,800,1000,1500,2000 grit wet sanding followed buy polishing with mothers alum. polish. You can often just do 400, 800, 1000 grit but since I had all of them it makes a nice job prior to polsihing them with mothers.
I used a drill with differnt buffs on the end for final polishing but by hand works fine too. You can also buy a kit with rouge and buffs from sears or a really nice kit from http://www.caswellplating.com/index.html which will work faster and better then sanding but I used what I had and the outcome was just fine. To get the casting marks and rough texture off around the caliper mounts and axle area a flapper sanding bit with heavy grit would be needed and a file perhaps, I still need to do that for some of the finest marks but have yet to get around to it after a couple years
I've also done my stock SS brake rotors:
You can see my sliders in this shot albeit a little blurry:
And shaved the casting marks off my trees and polished them:
A little sandpaper, polish and hard work does wonders.
Good luck.
Gator, just occasional wax, mothers, simichrome or flitz polish once or twice a year is all that is needed to stay shiny. They're no different than all the other bare aluminum on the bike.
