Dyna Front Ends
Old Sep 30, 2016 | 06:30 AM
Kopazzz's Avatar
Kopazzz
Default Dyna Front Ends
Are all Dyna models outfitted with the same quality front-ends or do the lower-end Dyna's have cheaper trees/forks?
I love the look and quality of the wide glide front end and wondering if I should only look at wide glides or can I entertain other dynas?
Don't want a cheap front-end with light-duty forks as used on sportys.
Thanks in advance.
Old Sep 30, 2016 | 06:43 AM
loopie's Avatar
loopie
Thanks in advance.
THEY are all made in china under licence from showa in japan
Old Sep 30, 2016 | 06:53 AM
BMyers's Avatar
BMyers
What makes you conclude a sporty has a cheap front end ?
Old Sep 30, 2016 | 10:03 AM
Kopazzz's Avatar
Kopazzz
I didn't mean to offend the Motor Company. One of my bikes, in fact the first Harley I owned, is a '72 Iron Head Sporty and the front-end leaves a lot to be desired. Of course that was under AMF ownership and a long time ago. My bad.
Old Sep 30, 2016 | 10:09 AM
jz78817's Avatar
jz78817
the only Dyna which doesn't have the small forks is the Switchback, which uses the FL front end.
Old Sep 30, 2016 | 10:18 AM
cggorman's Avatar
cggorman
49mm is a "small" fork now?!
Old Sep 30, 2016 | 10:42 AM
Yukon42's Avatar
Yukon42
I was wondering the same thing!
Old Sep 30, 2016 | 11:09 AM
F86's Avatar
F86
I would say that a 1972 front-end from any bike would leave a lot to be desired compared to it's current counterpart...
Old Sep 30, 2016 | 11:17 AM
cggorman's Avatar
cggorman
To answer the OP directly, the quality is the same across the lineup. Most internals are the same/similar. Other than rake/length/brakes, differences are cosmetic.
Old Sep 30, 2016 | 11:32 AM
cvaria's Avatar
cvaria
Why so much rage. Dynas have switched to 49mm... the tubes are mostly the same outside of length on all but the defunct switch back and the superglides. Im thinking it would not hurt for you to go and review the current state of things...
