In here from the high desert...questions
No brake feel in rear.,floor boards with forward controls,bushings inbetween floorboards rotted ,so I pulled the two halves apart and wiped off the chrome lower halves.
Has click,ordered a solinoid rebuild kit and a set of James inner and outer primary gaskets to start things off.
S&S carb with lever lifted up on full choke..click.....click......fire..high idle for awhile..push the lever down half to slow idle,let it sit there and run five minutes to warm up..then ride off.It pops bangs and hesitates for a few minutes until it warms up further,id say to full operating temp,then rides the freeway fine.P.O,said clean out carb and needles.I'll take it apart first,to determine if a rebuild kits needed.Oh,btw..sometime before he left (the earth) he carefully separated and categorized the shop manual in a large three ring binder and made a hand tooled stiff leather tote with a thin plywood back that attaches to the rear of the backrest..good stuff,the guy cared for this cycle.Did research on H.D. Models through the years and read the article 'H.D. The sweet years" before I decided to track down an FXR Evo.
Enjoy!
I'm not sure what kind of help I may need just yet...I'm starting on the simple stuff first,carb clean,solinoid rebuild...fluids changed out..etc...to get to know the bike a bit.
Throw my number in your cell in ya want,760.881.2656.
Thanks Nox,
Wasn't a hard choice at all.
I let it idle 5 min or so..
Want to take carb apart and have a look around in there though,between initial warm up and full opperating temperature it has severe hesitation and backfire like a semi auto .22
I ran some b12 chemtool through a tank of gas,didnt do diddly.
The FXR was my intention as the first Harley in my life.
