HOG won't start
Old Jan 3, 2017 | 12:54 PM
danhahn's Avatar
danhahn
If the ring gear is spinning but the primary chain is not, it seems to me it has to be a mechanical failure between the ring gear and primary chain sprocket, not electrical.
Old Jan 3, 2017 | 01:20 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by WH1_T-type
Just curious, what is the actual voltage your battery reads at before you hit the starter? Previous experience tells me a battery charged to 12v, while will read good to pretty much anyone, won't start the bike.
The ONLY way to test a battery, is to load test it.
Old Jan 3, 2017 | 01:21 PM
NORTY FLATZ
How to the teeth look on "#1" pinion gear?
How do the teeth look on "#2" ring gear?
Old Jan 3, 2017 | 04:35 PM
WH1_T-type's Avatar
WH1_T-type
Not true at all. Quick reading across the points show less than 12.8? Won't start.
Now if I does read good, obviously they have to load test.
Old Jan 4, 2017 | 03:39 AM
CowboyFrank's Avatar
CowboyFrank
NORTY FLATZ, the teeth on both look fantastic. Like both are new. As someone else mentioned earlier, if the part is supposed to be pressed and is not, this could be the problem.
Old Jan 4, 2017 | 02:19 PM
jbooher18's Avatar
jbooher18
Do you have an alarm on your bike?
Old Jan 4, 2017 | 04:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted...
Old Jan 4, 2017 | 04:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted again....
Old Jan 4, 2017 | 04:16 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Have you read all the posts in this thread?
The starter is being energized, but the engine does not crank...
The OP`s description points to a mechanical failure.
Old Jan 11, 2017 | 07:42 AM
danhahn's Avatar
danhahn
Did you find out what the problem is CowboyFrank?
