Vinyl Wrapped
Old Jan 9, 2017 | 01:14 AM
Deucedog's Avatar
Deucedog
Check this guy out. I know that he's done ATV's and some bikes. Ask him about wrapping bikes. I've seen his work and watched him do a tin set for a bike. NO problems with wraps peeling off. If the vinyl peals then I think it's an issue of preparation before applying it.
http://www.wrapthatcar.com/gallery/
Old Jan 9, 2017 | 01:03 PM
Lambda's Avatar
Lambda
I did mine in 3M vinyl, whole bike.
Tips
Use 3M Primer 94 to avoid heat peeling off the vinyl from the edges.
The rear fender is a PAIN IN THE ***, its better to do it on 3 layers (top and both sides) and use the primer well unless you want the sun to peel off the edges.
Be careful with any metallic things that may hit the tank as it will damage the vinyl.
The tank can be done in two layers, right and left, leaving the "cut" below the dash panel.
Any questions just ask, I have wrapped a batwing too so I've got some experience in harley wrapping.
Old Jan 9, 2017 | 09:38 PM
DonN's Avatar
DonN
Good work. Can you show a close up of the rear fender? How much does the seam between the vinyl show through?
Tips
Old Jan 10, 2017 | 11:45 AM
Lambda's Avatar
Lambda
I do not have closeups pics at hand atm, but that picture was from the first attempt, that attempt was with a single vinyl piece stretching it and it didn't work good at all.
The second attempt was by doing it on a 3 piece, top, right and left, without much luck anyway, I didn't let the prime 94 cure and some of the edges came away anyway.
There's a youtube video about a guy wrapping the rear fender on vinyl.
Old May 4, 2017 | 01:24 AM
Outdoor_funguy's Avatar
Outdoor_funguy
3rd Gear
Originally Posted by kgfrew
Has anyone here had their tins vinyl wrapped? I am having a hard time finding references so thought I'd ask. I am planning on stripping my bike (2001 super glide) apart here in the next couple of weeks (after I move) and having my tins wrapped. I love that Red Sunglow color so I'm leaning toward some kind of sexy red like that, then have them use the new decal badge from the 2017 lowrider. Post pictures or advice for me, thanks in advance.
If it's a vinyl wrap, contact Gatorwraps, they wrap all kinds of crazy things and lettering decals. You might also want to check Gatorprints.
baka1969
Aug 24, 2016 11:09 PM
hd96heritage
Exhaust System Topics
Nov 4, 2015 09:43 AM
Temporary Username 1
Aug 28, 2014 09:31 AM
Dynam1te
Apr 1, 2013 09:14 PM
maryland blackout
Dec 28, 2010 08:41 AM
