Turn Signal Stock issues.
Old Jan 9, 2017 | 09:16 AM
HotRodNut's Avatar
HotRodNut
Default Turn Signal Stalk issues.
This is to caution anyone installing the Turn Signal Stalk from the Directional Relocation Kit #53968-06C which is required to install the Docking Hardware Kit to mount the Sissy Bar.
The Stalk #68664-06A, Photo 1 in the attachment;
Item 4, Photo 2 in the attachment;
Pictured in Photo 3 in the attachment with the threaded end snapped off.
As you can see in Photo 3 the actual material left after the threads were cut and the hole in the center was drilled for the wires to go through may have .060” of material left. Not much material to do any torqueing on or making for a solid foundation to mount the light to.
The instructions calls for the Jam Nut, Item 3 in Photo 2, to be tightened against the lockwasher, Item 2 in Photo 2, to 8-10 ft.-lbs while holding the Turn Signal Housing, Item F in Photo 2. Well that’s kind of hard to get a Torque Wrench on with the Housing in place.
I did the best I could for Torque feel and felt if anything I had not tightened it enough, but after 3 days or riding the Stalk broke off as shown in in Photo 3.
When installing the new Stalk I was even more cautious tightening the Jam nut, I used a heck of a lot of Locktite and hardly tightened the Nut this time. Hopefully it will hold.
The Design intent is great but the actual design needed to include a new Turn Signal Housing that had a much larger threaded hole in it to allow the Stalk threads to be larger also, IMO.
Photo 4 in the attachment is the final Assembly of the Directional Relocation Kit.
I’ve rode about 50 miles since the re-install, hopefully it will hold without coming loose or breaking. I’m wondering if someone accidently bumped it if it’d snap off then.
FloridaRoy
Electrical/Lighting/Alarm
Apr 3, 2017 04:34 AM
drivingforce77
Jun 21, 2012 03:40 PM
love2ride71
Jul 23, 2010 01:11 AM
eddie57
Apr 15, 2009 10:10 AM
jetwizard
Apr 7, 2008 09:35 PM
