Fxdwg Shocks
That front needed to be done though, and with a quickness; it's wildly under sprung for a bike of this weight. I could easily bottom out the forks during threshold/maximum braking practice and the front had head shake during deceleration, unstable with surface irregularities, and felt nervous and wanted to drift wide during cornering.
I installed the Progressive Heavy 11-1546 springs and followed Progressive's recommendations on 15wt fluid, spacer length, and fluid measurement; the difference was like night and day. The bike is firm and planted under heavy braking practice, she's solid and stable in corners; the bike feels solid now, not squirming about.
Those springs are most likely why I didn't bother with the rear shocks; she's that good now; those Heavy springs are one of the best bang for the buck upgrades you can do; cost you just over one Benjamin. You'll find best pricing of the Heavy springs on Amazon and it will take 2 liters of 15wt fork fluid to do the job on these 49mm forks. This is a job you can do yourself with a lift and a few simple tools and it's an upgrade every Wide Glide owner should do. When you see the garbage HD put in those front forks, then you'll understand
One day I'll be looking at Öhlins for the front, but for now, I'm a happy camper...
Ended up going with #3, #3 B Ohlin's Blackline adjustable height shock. He suggested several different models, but in the end the one I went with met everything I was looking for.
