Low Rider S tuning issues
Old Jan 25, 2017 | 10:18 AM
spicoli.j's Avatar
spicoli.j
Default Low Rider S tuning issues
I've got a 2016 Low Rider S, and I'm having trouble getting a Power Vision to work.
When I turn on the bike, it starts to read the stock map/marry to the bike, then shuts off completely.
Is this a known issue with the "keyless" bikes? Has anyone else experienced this?
Checking here before calling Fuel Moto.
Old Jan 25, 2017 | 10:32 AM
rbdub474's Avatar
rbdub474
I've got the same bike and tuner, which I got from Fuel Moto. I had no issues installing the tuner/new map on mine. You might want to hook up to your computer and make sure the software and firmware is up to date. Otherwise I'd contact Dynojet tech support.
Old Jan 25, 2017 | 11:23 AM
CryingJoker's Avatar
CryingJoker
What he said. I have the same combo as well from fuel moto. Absolutely no problems for me and then sent to my dyno guy and he had no problems either hooking up to his laptop. I'd check the firmware and make sure it's up to date then call dynojet.
Old Jan 25, 2017 | 09:41 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Sounds like you may using an earlier PV device to read a newer ECM, if this is the case you will just need to update the firmware with the PV Update client and make sure everything is current. If you need any help just let us know.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
aaron___92
Apr 29, 2018 04:47 PM
sg2007
Apr 12, 2015 07:58 PM
ghoticov
Aug 1, 2014 02:01 AM
buxbike
Oct 1, 2013 12:24 PM
mathew2172
Dec 13, 2012 11:56 AM
