Can someone measure their wide glide?
Old Jan 26, 2017 | 08:01 PM
ryanobrian's Avatar
ryanobrian
Default Can someone measure their wide glide?
I know the length it 96'' and the wheelbase 67''....
I'm going to be picking up a 2013 Wide Glide and using my 3 rail motorcycle trailer (no going diagonal). the length of the trailer rail is 84'' and I'm not sure if it's going to fit or not....
Can someone please measure the length from the front tire where it would hit the chalk, to the back of the rear tire where it would touch the ground?
Much appreciated!!!
Old Jan 26, 2017 | 08:12 PM
TinCupChalice's Avatar
TinCupChalice
Just went out to the garage; my '13 Wide Glide is on the J&S lift but the best I can figure with a tape, from the contact patch of the rear tire to the leading edge of the front tire is 83"...
Old Jan 26, 2017 | 08:35 PM
ryanobrian's Avatar
ryanobrian
**** that's close! So if you put the front tire against a wall... would that be from the wall to the back tire contact point. Or, is that front tire contact point to back tire contact point?
sorry, just trying to make sure this will work before I drive 4 hours
Old Jan 26, 2017 | 09:00 PM
TinCupChalice
That's from the leading edge of the front tire up against a wall to the rear tire contact patch; and yea, it's going to be close on an 84" trailer rail
Old Jan 26, 2017 | 09:02 PM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
^^^What a guy!!!
Old Jan 26, 2017 | 10:45 PM
ryanobrian's Avatar
ryanobrian
Thanks a ton man. I think I'll be good to go since the front of the trailer is at and angle anyway. I owe ya a beer!
Old Jan 27, 2017 | 02:04 PM
mcraige65's Avatar
mcraige65
I measured my '15, and it was 83" from the leading edge of the front tire to the rear axle.
Old Jan 27, 2017 | 02:45 PM
TinCupChalice
Cool! Thanks for the confirmation; my '13 is up on the J&S lift so it wasn't as easy to run a tape on it but now you've made it official. I hope ryanobrian gets his new Wide Glide home safely
Old Jan 28, 2017 | 04:04 PM
103luckygreenDude's Avatar
103luckygreenDude
Here's an idea, let the air out of the front tire, that might pull it forward some.
hellonewman
Feb 13, 2020 10:18 AM
Jdimuzio
Aug 13, 2017 02:33 PM
Cobrettysw
Nov 18, 2012 09:15 AM
DynaGuy77
Feb 4, 2012 01:40 PM
drstephennix
Wheels/Tires
14
Oct 31, 2009 12:44 PM
