inherited a 2012 Switchback - 4000 miles - insane vibration at 2500-3500 rpm
lotta buzz on internet - many similar complaints
what's the fix - why doesn't HD have an answer?
It's really helpful to be as descriptive as possible when it comes to these sorts of issues Is the vibration more intense on acceleration or decel? Do you experience any sort of shuddering on decel?
Dyna's are a special animal and their alignment and isolators play a key role in them being either right or not. The front isolator is a known wear item; I changed mine out at 600 miles on the ODO but by setting up the bike correctly at that point the issue has not returned.
A few links to help get you started, the HD service bulletin is from May of '12. The monster shimming thread is a good read and you'll find good information within that...
Text Below is not from me, credit to the op who wrote it, but basically this is the problem and how to fix it.
The vibration between 2.5k and 3.5k rpm on many, but not all, Switchbacks is a notoriously well known problem. Here's the fix for that Switchback vibe problem:
On the bottom side of the muffler near the middle there is a bolt that attaches the muffler to the center of the support bracket. Temporarily remove this bolt completely. Start the bike. Run the engine up to 2,700-3,200 RPM and you will most likely notice the horrible vibration is gone. Replace the bolt with a clevis pin, a couple of fender washers, and a couple of rubber washers. (You often see this referred to as the "Clevis Pin Mod") This will keep it from falling off the bike if the rear bolt comes lose but it will let it float a little and remove the solid attachment that causes the resonance and vibration. You've "rubber mounted" the vibrating area of the exhaust system that causes the problem.
NOT QUITE as simple as this as it does take some finessing, juts loosening that cross bolt will move the vibration range down lower in the rpms
Yes that was my experience. When I did the clevis pin mod at first I got the assembly too tight- vibes moved down the rpm range. Then too loose- same. Finally just right and perfect now. No bothersome vibes. You have to play with the thickness of the spacers.
When I got new tires put on by an indie shop they removed the muffler and when they put it back they had lost a thin washer and the vibes were back so I had to re-do the connection and now all is good again. I will add that I bought my Switchback used and the dealer had put on a Nightstick slip on muffler and I am still using that.
I had a noticeable increase in vibration on my 2016 FLD after my dealer installed a stock head pipe sans cat. The bike also runs a Vance and Hines slip on, a Screaming Eagle intake and is Power Vision tuned by the dealer. Performance markedly improved after the install and the tuning but the increased vibration was noticeable. I decided to try the clevis pin fix and it worked. Vibration is cut by 50 percent and I'm happy.
