Vin error
Old Mar 27, 2017 | 11:46 AM
jonnym61's Avatar
jonnym61
Originally Posted by NORTY FLATZ
Sounds like you're due for a new battery, regardless.
What other mods does the bike have?
FP3 is something I'd look at.
i did the FP3, k&n filter and v&h short shots, nothing else.
yea I think you are right re the battery
Old Mar 27, 2017 | 12:22 PM
user 8382390's Avatar
user 8382390
Default Vinner?
Are you sure the message isn't v inner instead of vin error?
VINNER is the message you get when your battery is either too low or a loose connection to the battery. Since you ran the battery completely dead it most likely is no longer holding a charge. I got this message after a winter of the bike sitting up ( on a tender) and she just wouldn't hold a charge for more than a day. Installed new battery and no more error messeges.
Old Mar 27, 2017 | 02:06 PM
jonnym61's Avatar
jonnym61
went out to check again and she wasn't displaying any error and tried to start for the first so I think that might have been it
Old May 5, 2019 | 07:08 PM
pat2330b's Avatar
pat2330b
1st Gear
Default Replacement of the speedometer with a used one
Hi i m new to this forum. I have a 2015 breakout. Just install a used speedometer not knowing that the replacement whould be an issue. The VIN ERR message is always on the bottom of the sceen. After reading this post i realise the problem could maybe solve but he procedure proposed in this thread is mayby now the good one for me. Does anyone know if a procedure for my issu have been post on this forum?
Glad to be part of this forum !
Pat
Originally Posted by Robottom
VIN error means that the speedometer is not recognized by the ECM. This usually occurs because you have installed an aftermarket ECM (Replacement EFI Tuner) or have replaced the speedometer with a used one (already married to a different ECM). It's also possible that the speedometer or ECM memory somehow got corrupted. New speedometers will accept recorded mileage from the ECM and once synched will only work with that particular ECM. I don't know if there is a way to reset the speedometer to act as new and accept a new marriage to a new ECM. The ECM is programmed to complain if it doesn't recognize the speedometer. The ECM wants to know that the Speedometer is displaying the correct mileage for your motorcycle.
OK, having said all that, the bike should still start and run even with the VIN error assuming that the battery is charged properly. I think the MPH / KPH needle should still work too.
Old Jul 4, 2019 | 09:44 PM
Black2012beast's Avatar
Black2012beast
3rd Gear
Default Vin Eeror
I recently had the same thing happen on my 2015 Wide Glide.
My bike was having a hard time starting. Like it was almost frozen. It was throwing the Vin Error code when hitting the run switch but eventually would turn over. No check engine light or anything though. So one day I started poking around and found that the battery tender cable that comes out through the battery box had a cut in it and the wires were exposed. Basically touching the box. So I taped it up and put the tender on it to make sure it still worked and the battery was charging. Found that my battery cables that attached to the battery were super loose on both neg and pos. Tightened them down good and have not had a prob since. It appears that these bikes are super sensitive to any electrical disturbances. It seems like because of the vibration from the bike you have to check the cables frequently since they have a tendency to come loose. Fingers crossed that it doesn’t happen again.
Old Jan 12, 2025 | 08:17 PM
ayyPanini's Avatar
ayyPanini
Stage I
Has this problem been fixed currently? Because I am experiencing the same situation, I would like to know how you fixed it.
Veritas01
Jul 4, 2019 04:07 PM
mgb1
Feb 16, 2019 06:00 AM
mgb1
General Topics/Tech Tips
Nov 13, 2018 10:30 PM
mgb1
Sep 30, 2018 01:36 PM
EZ48
Aug 27, 2009 05:08 PM
