Learned a trick when replacing my jiffy
Old Apr 6, 2017 | 10:32 AM
TUCCI's Avatar
TUCCI
Default Learned a trick when replacing my jiffy
Thought Id share a trick I learned when I swapped out my chrome jiffy for a black one. Worked like a charm:
https://www.hdherd.com/forum/technic...kstand-install
Old Apr 6, 2017 | 10:51 AM
cggorman's Avatar
cggorman
Clever trick. I wonder how the factory does it?
I've got a pivot block replacement in my future. It's wallered out pretty good from 18 years of use.
Old Apr 6, 2017 | 10:56 AM
Prof Rene's Avatar
Prof Rene
I use a screwdriver to put the spring back on or my brake drum spring tool.
Old Apr 6, 2017 | 11:50 AM
Stick_FSMC's Avatar
Stick_FSMC
I've done both of those methods, both worked, but were a pain in the ***. I tried the washer method last time I had to replace a spring. Worked well.
Not many people have a Drum Brake spring tool laying around any more. Not a lot of people who still work on drum brakes.
Old Apr 6, 2017 | 12:31 PM
TexasMotorcycleRider's Avatar
Originally Posted by big d
note that the calculator was not used in this task; it was just sittin' there. :ha
lmao!!
Old Apr 6, 2017 | 12:46 PM
TUCCI's Avatar
TUCCI
Wondered that myself when contemplating the removal. Its guys like the one in the link that have saved my *** on many occasions. Thats why I always repost, its a debt I owe every time.
Old Apr 6, 2017 | 01:18 PM
RANGER73's Avatar
RANGER73
I find that if I remove the jiffy stand from the bracket, hook both ends of the spring, with the jiffy stand pointing toward the front, I can pull the Jiffy stand enough to insert it into the bracket, flip it to the up position and install the top key and bolt.
Old Apr 6, 2017 | 01:51 PM
Prof Rene's Avatar
Prof Rene
Yeah I don't do drum brakes often anymore, but always keep tools like that they can be really useful. I actually put a stove spring back on with it.
I am going to try the washer method next time I do it, because it is a smart way to do it.
Old Apr 6, 2017 | 01:52 PM
sharkey's Avatar
sharkey
I've got a spring tool, cheap...put spring on somewhat like ranger said. The washers (or coins) works well, too. When I had the stand off the wifes Low Rider, to add to the tab so bike would rest more upright, I also fitted an oillite bushing in the block. Smooth and no slop now!
Old Apr 6, 2017 | 02:41 PM
Stick_FSMC's Avatar
Stick_FSMC
I have to keep the drum tools handy. Wife's 2003 Dodge van has rear drums. Also, my 1962 Chevy truck has 4 wheel drums.
