O2 sensor socket... size?
Old Apr 21, 2017 | 03:04 PM
JuanderBoy's Avatar
JuanderBoy
Originally Posted by Smogbob
Also do not get any antiseize on the heads or your ride will start throwing error codes, just put a tiny bit on the threads, and make sure you do not touch the heads with your fingers, and you will be good.
This is gold, this is stuff that I haven't seen on videos or on the manual and it will save me a lot of pain. Much appreciated. I'll post pictures when I'm finished. Seems like a 2 hour job with translates into a 2 day project based on my knowledge and skills.
Old Apr 21, 2017 | 03:17 PM
Smogbob's Avatar
Smogbob
Just take your time and enjoy, do not force anything, it normally all goes into place, if it is to tight or you need to force, that is not good, make sure you remove your battery if it is like my fatbob on the side, it makes the O2 sensor under the seat easier for removal, as the O2 sensor cable is threaded throught the battery cables, and before you pull it through, put a long piece of string around the sensor under the seat so you know which way to pull it back through when you are installing, the sensors, also, good little tip is to double nut your header pipes, this will stop you losing your header nuts later, do not put loctite on header nuts, it melts and makes nuts slippy and they can loosen alone.
Old Apr 21, 2017 | 03:23 PM
JuanderBoy's Avatar
JuanderBoy
I hope you know I'm copy/pasting all this on a sheet I'll have right by the tools when I work on this.
Old Apr 21, 2017 | 03:35 PM
Smogbob's Avatar
Smogbob
No shame there, sometimes I put my laptop in the garage, to read things while I am doing it, or to look at a video, take your time and nothing will break.
OldPhat
Jan 18, 2013 08:53 AM
fat bastard 68
Jul 5, 2012 12:35 AM
racngrn
Apr 25, 2012 07:28 AM
1931jamesw
Jun 7, 2010 01:28 PM
Dango
Dec 23, 2009 10:29 AM
