Beefing up the clutch?
Old Apr 27, 2017 | 11:34 AM
cvaria's Avatar
cvaria
Thumbs up
Originally Posted by mattVA
Good deal. You need to get really familiar with the Big Boyz Twin Cam calculator when planning an engine build. When you plug in the spec for a a 107, 110, etc and enter the specs for 79cc heads and pick a cam. .you'll see real quick why those heads won't work. Compression would be through the roof.
man, that's nifty
http://www.bigboyzheadporting.com/TwinCamComp.htm
Old Apr 27, 2017 | 11:37 AM
Sunday's Avatar
Sunday
Originally Posted by Ghost_13
Runnin this one - it a good-n
Ghost
http://www.barnettclutches.com/scorp...omponents.html
I agree with Ghost. I run one in my LRS (117" 132 hp/138 ft lbs) and Softail Custom (120" 145 hp/134 ft lbs). They come with multiple springs (except the Red 100#) so it can be adjusted for more or less if needed.
Old Apr 27, 2017 | 05:30 PM
Max Headflow's Avatar
Max Headflow
If you got an early bike, speed.. What works really well is barnett carbon fiber, stock plate count clutch, the 480lb Barnett spring, and an easy boy arm.. You can get all the parts from Jireh for about under 150 IIRC. I've used this clutch in my 00 116 ci dyna for about 40,000 miles.. A couple 1000 ago I had to replace the spring tho.. Motor made about 125hp/130 tq the last time is was on the dyno..
One thing to note is that you need about 6% more holding over a 6 speed bike as the primary gearing is different.. If running a 24/37 primary gearing you need about 14% more.
beammeup
The Dyno Room
May 10, 2016 08:43 AM
XFXDX
Mar 20, 2015 07:42 AM
RKGDCG03
Feb 12, 2015 08:49 PM
hydrolock43
Nov 29, 2011 02:24 PM
opa
May 23, 2006 05:38 PM
