Does anyone else's fuel tank groan?
Old Apr 24, 2017 | 08:52 PM
Nickd2689's Avatar
Nickd2689
Default Does anyone else's fuel tank groan?
so when people smoke, they go in the garage. A few people have told me my bike was making noise and sure as hell it sounds like a slow whine/groan noise from the tank. Twist the cap off and it stops. I know temp differences cause expansion but I've never had any bike do this. Not worried by any means, but have any of you experienced this?
Old Apr 24, 2017 | 09:00 PM
Campy Roadie's Avatar
Campy Roadie
Fuel vent line is restricted.
Old Apr 24, 2017 | 10:31 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Big Mikey makes his bike groan everytime he sits on it!
Old Apr 24, 2017 | 10:37 PM
fxdx1985's Avatar
fxdx1985
Only if i touch it in the right spot
Old Apr 25, 2017 | 06:10 AM
TinCupChalice's Avatar
TinCupChalice
^^^^^ This
Check the vapor line and the vapor valve. If the line is clear delete that stupid EPA vapor valve, I'll bet that's the source of the sound; replace it with a straight vacuum hose connector. I'm venting the tank directly to atmosphere, no moans or groans.
Yea, I'm a loner, a rebel
Old Apr 25, 2017 | 06:15 AM
Uncle Larry's Avatar
Uncle Larry
Only if I stick the nozzle in ALL the way
Old Apr 25, 2017 | 06:21 AM
TriGeezer's Avatar
TriGeezer
Do you have to wiggle it around then?
Old Apr 25, 2017 | 06:27 AM
TUCCI's Avatar
TUCCI
I've got vapor line that sticks out below the bike between the rear engine mount. It's rigid and occasionally leaves a drop. I can smell fuel vapor once in awhile when I'm laying on the ground whipping down the undercarriage. If anyone can expound on deleting the vapor valve TinCup has mentioned please share your project.....thanks
Old Apr 25, 2017 | 07:12 AM
ElliotDenson's Avatar
ElliotDenson
Touch it in the right spot
Nickd2689's Avatar
Nickd2689
Thanks. I did check the vent line which is clear and not kinked. Was just really surprised to hear this......I like em noisy......
