ppu 52304
Old May 10, 2017 | 03:31 PM
goathead743's Avatar
goathead743
6th Gear
Default ppu 52304
Hello. I have an '03 Dyna Superglide (FXD), with a factory carb. No spark to the rear cylinder. Plugs, wires are good. Swapped out the coil, so I doubt I'd have 2 bad coils. Diagnostics show " do1CLr, do2CLr" up to 10. Then I get PPU 52304.
Can someone help me find out what this code means?
Old May 10, 2017 | 05:39 PM
TUCCI's Avatar
TUCCI
Welcome to the forum...put that question out to the google world if no one is able to help.
Old May 13, 2017 | 07:36 AM
goathead743
6th Gear
Okay. I still can't find an answer to my diagnostics problem (ppu 52304). So, has anyone in the forum used a product "motoscan" by Diagnostica. It's quite a bit of money but may still be cheaper than leaving my bike at the shop.Thanks.
Old May 13, 2017 | 09:06 AM
beanoboy's Avatar
beanoboy
Google says 'do1 clr' upwards are Speed sensor faults, or voltage regulator...b.
Old May 20, 2017 | 01:34 PM
Fxdwg3-2002's Avatar
Fxdwg3-2002
Stage I
Default Same problem
I got the same probleme sames code with my wide glide 2002... and speedo seem to be faulty
Papa Georgio
Jul 26, 2011 11:23 PM
FLAMED96
Jul 3, 2011 06:16 PM
convictedsoul
Sep 28, 2010 10:45 PM
jcuttito
Mar 19, 2009 02:39 PM
motomaxx
Mar 24, 2008 04:46 PM
