First gear gear hard clunk,
Old May 13, 2017 | 03:16 PM
kcollins's Avatar
kcollins
Default First gear gear hard clunk,
sometimes from dead stop, on 2013 fxdc, from nuetral to first gear causes a really hard and loud "clunk" sound. whats that about? any help advice is appreciated.
also often when slowing for a stop, I'll down shift to what i swear is first, because it will literally not go down any further. Even while stopped it will not go down, but then on take off, surprise! its in second gear. and then once im rolling again it will go down into first..
could these issues be related? is it shift linkage? or am i just a dip..
Old May 13, 2017 | 03:20 PM
retxpres's Avatar
retxpres
I like to use Amsoil Gear Lube. Loud clunk is gone.
Old May 13, 2017 | 03:22 PM
skid_pimp's Avatar
skid_pimp
Clunking loudly when engaging first is typical for a HD, supposedly it is slightly better in 2017 M8 models. If you are having difficulty engaging first altogether, I would suggest checking the adjustment and condition of your linkage and shift mechanism as well as ensuring your shifter is not hitting your boards if you have them. And then lastly you may need to adjust your clutch. What speed are you trying to engage first at when rolling to a stop?
Old May 13, 2017 | 04:27 PM
archergodwin's Avatar
archergodwin
Very typical 1st gear clunk.
Now then... when rolling to a stop, I'll downshift to 2nd ( with a quick clutch pull and blip of the throttle), and then shift into neutral... while still rolling...and with clutch still in from going into neutral, I'll down shift into 1st, just before I come to a stop. Makes it easy and no loud noises.
ADD: Also, put in a nice gear lube... makes it easy to find neutral.. very easy... I use a 75/90 during colder seasons, and 75/140 when it's hot.
Old May 13, 2017 | 04:54 PM
freebaggin's Avatar
freebaggin
My 15 FXDB, always a loud clunk into first gear when I fire it up in the mornings or after sitting at work all day, rest of the time its usually pretty quiet and smooth. When I down shift my gears finding first or neutral are no problem but if come to a stop from 5th or 6th gear and didn't downshift then it can be a lil sloppy finding first and neutral and I'll have to let the clutch out a lil to re-align the gears and drop one or two and have to let the clutch out a lIl again and **** down into 2nd and first, this can be done while stopped and waiting at the light, it dosnt always do that but it does about 25% of the time, not a big deal since I usually always downshift. Rest of the time she's smooth as silk.
Old May 13, 2017 | 05:12 PM
kontiki's Avatar
kontiki
I see this once in a while on mine also. Coming to a light I know it didn't get all the way down to 1st and then it won't go to 1st sometimes until I let out some clutch to move the gears a bit. Just takes fine clutch control.
If I hold the clutch in when starting and hold it until ready to go into 1st I get no clunk.
Old May 13, 2017 | 05:14 PM
esteboatan's Avatar
esteboatan
I had the same clunk in my FXDC too, ended up going with Redline synthetic gear oil with Shockproof and the clunk is much much quieter.
Old May 13, 2017 | 06:51 PM
Suede Blue Man's Avatar
Suede Blue Man
Might not hurt to take a peek at the primary chain tensioner and make sure it's in working order/adjusted correctly.
Old May 13, 2017 | 07:24 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Do your homework. Make sure the clutch back off is correct at the clutch behind the derby cover. Then adjust about 1/16" play at your lever. Make sure you have the correct straight weight non-detergent gear oil in there recommend by Harley (there is only one). Make absolutely sure the oil is at the bottom of the diaphragm spring when you check it after putting the correct oil in there.
For these transmissions to shift correctly, the clutch drags slightly and always spins the big cluster gear shaft. That clunk is that shaft stopping. If it is not spinning, sometimes, if the dogs do not line up, it actually will not go into gear.
To get it to totally stop spinning so you can see what I am talking about. This need to be done on concrete or rough asphalt. Put it in neutral, pull in the clutch and start it. While holding in the clutch, blip the throttle about 400 rpm and let it fall back as you either push it back with your butt or just rock it back and forth. Continue doing this till it falls off to idle. This will free up the stuck drive and driven clutch plates that get stuck with an oil film. It may take a few tries to get the hang of this with your clutch. Mine takes a good minute when started up cold. However, once broken free, it will drop in gear with no bang whatsoever, or actual not go. If it does not go, just let out the clutch in neutral, pull it back in will spin things and hit low again.
Old May 13, 2017 | 10:36 PM
rjo3491's Avatar
rjo3491
...all my bikes including the Dyna have had a first gear, "klunk" (even the rice burners) - it's pretty normal. I will try the oils noted above and see if they help.
