Couple quick low rider s questions
Old May 21, 2017 | 11:11 PM
imboden's Avatar
imboden
Default Couple quick low rider s questions
anybody put forwards on it?
comes with solo saddle, whats it look like with 2 up seat?
passenger pegs easy to put on?
Thanks. thinking about it.
Old May 22, 2017 | 12:26 AM
brasher's Avatar
brasher
1. Yes, same as every other Dyna to put on more or less.
2. Heaps of threads with people using Lucky Daves/Saddlemen/BMC/Lepera etc have a search
3. Yes, may have to loosen belt tension to put left side on but some can do it as is.
Old May 22, 2017 | 05:09 AM
petefwa's Avatar
petefwa
Swap the torx bolts that come with the rear foot peg kit for hex head bolts and fitting them is way easier.
Old May 22, 2017 | 09:24 AM
WH1_T-type's Avatar
WH1_T-type
As said above, the passenger pegs aren't hard and definitely replace the torx bolts. Some release belt tension because getting the tool in there to remove the stock bolts is a pain. If you are patient you can do it without doing that.
Old May 22, 2017 | 09:47 AM
Nickd2689's Avatar
Nickd2689
1-I put forward controls on mine in about an hour
2-I have a Badlander 2 up seat that I think looks good, however 99% of the time I use a factory street bob solo seat because I think solo looks better. Something about the rear fender it just looks best with a solo seat in my opinion.
3- I don't have passenger pegs on mine but they aren't hard to install by any means. If you install passenger legs, it's a good idea to spray rust penetrant in the threads and run a tap in them first. Same thing with forward controls.
Old May 22, 2017 | 09:58 AM
tasdevl's Avatar
tasdevl
I'm 6'3", works much better with the forwards
Romeo
Sep 10, 2025 04:25 PM
smittybald
May 21, 2019 09:21 PM
SigEpRider
Jan 24, 2015 11:11 AM
dmftoy1
Dec 11, 2009 06:55 PM
CHEESE
May 12, 2006 12:25 AM
