priamary seal and air cleaner 2007 dyna wide
Old Jun 10, 2017 | 09:54 PM
ron s's Avatar
ron s
Default priamary seal and air cleaner 2007 dyna wide
ok, i just change my oil on bike, 15500miles...and used revtech synthetic....i am going to change the primary too, with revtech chain oil....DO I HAVE TO GET A NEW SEAL ON THE CLUTCH COVER? i was also told to use blue locktight on screws
and the aircleaner,,,,,do i just take the filter out, and blow out the dust with my computer compressed air....and reinstall..thats it?
Old Jun 10, 2017 | 10:14 PM
robertomendo's Avatar
robertomendo
I don't know about the air filter questions but if you are careful with the derby cover seal you can re-use it several times. Look up how to change the primary oil on youtube for some good videos that explain re-using the gasket on the primary and pay attention to the torque on the primary screws, they take VERY little torque.
Old Jun 10, 2017 | 11:28 PM
mqqn's Avatar
mqqn
6th Gear
If the air cleaner element is the stock, dry paper filter, just swish it around in a bucket of water with a small amount of dishwash soap, then rinse it out with clear water and let it air dry for a day.
As to the clutch inspection cover, I bought a new seal for mine as I was not sure how long it had been in place (just bought the bike used in Feb) - and did not use loctite (was not called for in the service manual if I recall).
I did use proper torque as called for in the manual.
best
mqqn
Old Jun 10, 2017 | 11:33 PM
perki48's Avatar
perki48
The LAST thing I would do is use Loctite. Way to many people have problems stripping threads without using it. Been using original seal since new in 07'
Old Jun 11, 2017 | 10:52 AM
archergodwin's Avatar
archergodwin
If you have the o-ring style seal and not the flat standard gasket, it can be reused many, many times. Don't thread lock the derby cover, you won't need it, and as previously mentioned, they don't take much torque to stay tight... so... One thing I 'did' do, is toss the POS torx bolts and replace with allen headed polished stainless.
Old Jun 11, 2017 | 11:00 AM
TinCupChalice's Avatar
TinCupChalice
^^^^^^^ all of this
http://www.ebay.com/itm/5-Stainless-...item4afa558cdd
Old Jun 18, 2017 | 09:00 PM
ron s's Avatar
ron s
thanks all
Old Jun 22, 2017 | 10:32 PM
ron s's Avatar
ron s
Originally Posted by TinCupChalice
cool...will order..thanks for the help
janderson1964
Apr 1, 2015 10:28 AM
Roger Williams
Aug 14, 2013 05:10 PM
neonhomer
Exhaust System Topics
May 31, 2008 06:35 PM
heavypic
Jul 27, 2006 10:08 PM
hammertime
Dec 2, 2005 06:39 AM
